The Dark Side For those members running "Car Tires" on their scoots. This is for their discussion only and not a place for "non dark siders" to mouth off about their negative opinions of this idea!
2006 Dyna Wide Glide
Old Sep 5, 2013 | 07:51 AM
bobber4life's Avatar
bobber4life
Default 2006 Dyna Wide Glide
Howdy folks, newbie here. Trying to make the switch to darkside. I ride a lot. And am getting a bit perturbed by having to get a new rear tire 3 times a month. I ride a lot, did I say?
I gots me some questions:
I have a 160/70 B17 on my wide glide. Is the B17 the same as an R17?
And where the hell can you find CTs for this size?
I have found this:http://www.citytyre.co.uk/tyre-303-1...TONE_RE040.htm
A British 175/55 R17 I think will fit. Just not sure what the rules are for imported tires.
Another: when running tires for bikes, radials or bias ply? Coker makes some I think will fit but are bias ply, http://www.cokertire.com/m-h-front-r...165-70d17.html Good idea? Bad? Good stories coming from bad decision kind of thing?
Also, I am running a chopper rear fender. I have about an inch of clearance on each side and an inch above. Thus limited on size CTs.
If the pics work you'll see what I ride. Suggestions?
Attached Thumbnails 2006 Dyna Wide Glide-img_0035.jpg   2006 Dyna Wide Glide-000_00031.jpg
Old Sep 7, 2013 | 03:09 PM
bobber4life
Don't everyone reply at once.
Seriously, one at a time works just fine.
Old Sep 7, 2013 | 03:23 PM
FLHProadkill's Avatar
FLHProadkill
OK. I'll help ya out.... or lack of.
I put a CT on this year. I ain't never going back! Ya, there are some things ya gota get use to but you probably already know if ya read the posts.
Lot of interest fir the Dyna. Sorry I can't help there cause I'm running a RK.
Size is going to be a big problem. If it were me I'd do 1 of 2 things...
1. Sell the Dyna and get a RK or one with a 180-16. You'll have lots of tire choices. But... if I really liked the bike that won't work.
2. Put a wide tire kit on. Don't know if they make them for your bike but hopefully they do. Then you have your choice of tires. This is what I'd do.
Don't give up. I'm sure there is someone out there who has done this to meet your needs.
Post if ya find something.
Good Luck!
FLHPRK
Old Sep 7, 2013 | 09:30 PM
bobber4life
I'm gonna put MC tires on this time... again. But over the winter gonna be researching my butt off. May see if a 14", 15", or 16" will fit without too many changes. CTs in those sizes are a dime a dozen.
Old Sep 7, 2013 | 10:43 PM
FLHProadkill
Good luck with your research. I hope you find a solution. I know there must be a few following you and if you find a solution it may start something.
Maybe a custom wheel manufacturer has done this already?
Good luck and keep posting your findings.
FLHPRK
Old Sep 7, 2013 | 10:50 PM
perki48's Avatar
perki48
I have a 15" rim in my garage that I was going to lace for this very purpose. Then when I took my rear wheel off I realized that the 15" rim probably would not accept the brake assembly due to being to small of diameter. I have been searching for 5 years now and have not found a 17" that would work on a Dyna. Good luck.
Old Sep 12, 2013 | 08:51 PM
bobber4life
Just ordered a matched set, 16 x 5 rear and 18 x 3.5 for the front, off a road king I think. Hell the pair was only $125, maybe 50 miles on them, trade-ins. 1" axle. The Austone Taxi Tire will fit the rear. Haven't decided what I'm going to do with the front yet.
Old Sep 15, 2013 | 10:10 PM
fishbones's Avatar
fishbones
B= Bias ply R= radial
Old Sep 16, 2013 | 07:39 AM
bobber4life
Ahh. Thanks. Never would have thought of that. *smacks head*
Old Sep 16, 2013 | 07:44 AM
FXDWG12's Avatar
FXDWG12
Suggestions?
How about easing up on the throttle there bub?
