The Dyno RoomA special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
I have a 08 FLHX anniversary that I put 103 heads cylinders and jugs on with SE 255 cams
I loaded the Harley base map and tried to tune with smart tune ,still running hot and dropping rear cyl.
By chance does someone have an 08-09 103 ,SE 255 cams high flow air cleaner and exhaust that was dyno tuned that they could down load the program so I can compare with mine
Well actually.
Mine is an 08, 103 kit installed, SE 255 cams. K&N intake, stock headpipes with V&H slash slip ons. I just put the SERT on it this spring. I like the way it runs but it is really rich and mileage is horrible. I am planning on plugging into in the next week or so to check settings. I will see if I can pull the map for you to compare.
Sorry for the delay. When I pulled mine I found that it had the wrong base map used. Took it back to dealer and straightened it out. This is what mine looks like now.
08, 103, SE355 cams, K&N stage1 intake, stock head pipe, V&H hi flow slip ons. http://api.viglink.com/api/click?for...Y.dt0%3Fdl%3D0
