The Dyno RoomA special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
but presumably Winpep 8 is only going to show you what is in the PV log file as well
Steve / Gordon61, it does show what ever the pv software has logged. Here again there are no cells that do not have at least 1 decimal, example 100.47, 100.5, 100.06 etc. There is a bizarre twist though, you can adjust the map axis to the pv map points, they also have decimal points, but the rpms you can't. Pv set rpm points are every 125 rpm from 875-3000, then every 500 from 3000-7000 and then 7000/8000. The WinPep 8 uses decimal point numbers like 2.475842, 2.649158, 2.822474 etc. When you try to scale them to the pv rpm points you lose the data, they even have a couple of extra rpm points that the pv doesn't have, after that it's a headache to remove the program, search out some hidden files for setup, and then reload the app back in. I've tried 3-4 different ways with no luck. So I don't know if the numbers shown in WP 8 can be trusted.
I hate to say it but as long as PV knows what it is doing to the numbers it can work within those rules, but a third party program doesn't have a chance, unless it too knows what has been done to the data first. There are way to many things that are possible, to spend the time to figure out what they are doing, so unless one of you can get an answer from the source we would all just be guessing. This is just one of those little things that can really screw with you when your trying to look at what is really going on.
As I said before it could be some sort of running average of the raw values that are coming in. I myself prefer to work with the raw data so I do not have to worry about it.
It was just when you said it should be an integer so it must be wrong ...that raises an obvious question of "how wrong"
Sounds like it doesn't really matter tbh
It is not right, that's for sure, but if PV knows internally what they have done to the data, it may not matter,to them only. The downside is trying to use Third party software on already modified data. I can take the raw data use a formula to change the way it looks and then output that information. Once I've done that no one else is going to be able to understand the data unless they have the formula to get back to the real data.
So when you guys tell me it looks this way or that way in a third party software means nothing as what your using to start with has already been changed from what it really is.
I get the point about one person using their tools to look at data and everyone else not necessarily knowing what they are looking at (there have been one or two examples of late on that (cough))
But PV or TTS build logs by capturing data. What they capture is maybe debatable - is it an average since last time or is it the value currently in the ECU buffer ...who cares ...we are not getting all of the data anyway so we would have to interpolate in our head (or third party piece of software) anyway
Pulse width for example, what use is capture one, lose 20, capture 1, lose 20
The log is what it is and has to be analysed with that in mind. PV logging 14 samples per second ...fair enough, all you get with that is a trend
no?
Yes, people need to understand the tool they are working with and it's limits. So what may well work great in TTS maynot work well for PV and vis versa. We chose to output the data the way the ECM sends it out, and it appears from the data supplied, that is not what PV chose to do. Is that Good or Bad, who knows.
6000 RPM needs 50 fps data rate to collect all the raw data, so whatever rate your tool is getting this should give you an idea what is being missed
1000 RPM needs 9 fps.
6000 RPM needs 50 fps data rate to collect all the raw data, so whatever rate your tool is getting this should give you an idea what is being missed 1000 RPM needs 9 fps.
my bad ...couldn't do sums, missing 20 was obviously a bit of an exaggeration
It's all good, people just need to understand it is not what it's been made out to be by many internet sellers. There are some hard and fast things that have to be dealt with and there is only so many things that can and do cause changes. If you have a bike with a 4 pin connection (J1850) most tuners log at 2 fps and 6 pin connection (Can) 10 -14 is the normal range. While its not everything TTS has pushed hard to get data rates up when no one else thinks it matters. 4 pin at 5 - 6 fps for fuel data and 14 - 15 for spark data and 6 pin at 30 - 40 depending on ECM. When you have all this extra data to look at, things do appear different, but the higher data rates paints a more accurate picture of what is really going on.
That said you still need to understand the limits and accuracy of the sensors! Everything is based from the sensors so if you know it can and does move around, then seeing that movement becomes easier to understand. What becomes harder is to pick out when the movement is from the sensors or something else.
