The Dyno Room A special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
No Device: HD/Delphi EFI Tuning Basics
Old Aug 16, 2016 | 03:40 AM
  #211
mirrmu's Avatar
mirrmu
just following Steve's thread, members are questioning these significant issues that have been highlighted and now looking for feed back on them (as outlined in the first post the discussion is relevant to all tuning devices)
the data Gordon posted is at idle, see pg19 for more info
Old Aug 16, 2016 | 05:41 AM
  #212
Gordon61's Avatar
Gordon61
Originally Posted by Tsani
Gordon, were you able to recreate the circumstances that created the event and verify that The PV AT did indeed correct it? As you know, the devil is in the details. The Delphi ION sensing system does occasionally create or report a non-event as an event. Nature of the beast.
Short answer, I think so ...see the PV auto spark tuning or Mytunes? for further info see ...here...
Old Aug 16, 2016 | 07:36 AM
  #213
Gordon61's Avatar
Gordon61
Originally Posted by Fat11Lo
can you feel or hear the abnormalities that Steve pointed out in your log? Is this just a data log or is your tuner in AT at the time?
This was an example of a normal-notinautotunemode log covering a period of idling from initial start to EITMS kicking in. Can I hear the anomalies Steve pointed out? ...possibly, but I'll take that to a new thread on idling and the timing that hardtail noticed
I was under the impression that when using an "auto tune" type of device that changes should be checked by running a data log after changes are made.
Not all tuners can capture logs so maybe the general idea is to do your tuning, and verify with any other tools you may have, if any. The pro's have wideband and narrowband sensors they can compare for example. The DIY types can certainly use logs to get an idea how close the tune seems to be, but as discussed above, the question of sample rate and how such logs are created may raise a touch of doubt in what "exactly" they mean/show.
Old Aug 16, 2016 | 05:04 PM
  #214
Fat11Lo's Avatar
Fat11Lo
Originally Posted by Gordon61
This was an example of a normal-notinautotunemode log covering a period of idling from initial start to EITMS kicking in. Can I hear the anomalies Steve pointed out? ...possibly, but I'll take that to a new thread on idling and the timing that hardtail noticed.
The reason I ask is, I have read threads on here before where people have stated "the bike seems to be running fine" or "the bike has never run better, but I noticed when reviewing my last log ........"
I understand this, and I'm fully aware that $500 bucks for a little orange box or a gadget to mount on the handlebars a few cables and a computer program could never replace thousands of dollars worth of professional equipment. I also subscribe to the school of thought that the most important part of the equation is the Tuner(the person) not the device. I'm just trying to learn as much about the process as possible.
Old Aug 17, 2016 | 03:56 PM
  #215
Fat11Lo's Avatar
Fat11Lo
Originally Posted by hrdtail78
Are they issues? This is a PV log off a tuned bike. Does PV filter out this data? Does PV use this data? How are their filters set up? How is it set up in their auto tune to address this? Sounds like questions for DJ, because I can't see Steve caring. Why would he want to fix their stuff? This thread is a DH/Delphi Tuning Basic thread about basics. Not a particular tuning device.
So to better understand the data it's best to understand how a particular device collects that data and processes it? This will help to determine weather the data in question is a bad sample or something is malfunctioning causing the data to be skewed?
People wanted to see skewed data, and how that data looks. BAM, there it is, and thank you Gordon for putting it up.
Even though it is OT. I can tell you what I would do. First I would see if the PW match's what the O2's are seeing. Then I would sample with widebands while sampling with the narrow bands to see if I can verify the narrow bands. Then I would take the data I collected with the WB's and hand create a VE table in this area. Compare my hand VE's to AT VE's, and test again. That's right. I wouldn't use the AT that got me here in the first place, because doing the same thing will get me the same result. If my hand VE's were better. I have a choice. Leave them with hand created VE's and run that area in open loop or try and get the sampling better with the narrow bands.
Basic tuning 101
Basically you are using two sources to verify the data. Sounds like the same approach I use when troubleshooting a piece of equipment, I use the laptop to see what the ECM is reading and then use pressure gauges to verify what the sensor is telling the ECM
Old Aug 17, 2016 | 04:35 PM
  #216
hrdtail78's Avatar
hrdtail78
I don't know how DJ processes their data, but using tuners on other things besides motorcycles. I have learned that these things need to be set up in order to take out the junk data. Some tuners give you nothing and let you figure out all the PID's.
For example in Gordons log. O2 drops out but there really isn't an indication that it is going that lean. So, you filter out the data that does go that lean. All HD flash base tuners do this. Ever collect NB data and you are trying to hold a cell and O2's never come on line in some areas but you get data in the others? Wash that log through and some of the VE is changed and some isn't. Blend the cells that didn't get changed by the cells that did get changed so they are close and run again. Then all cells are getting hits. They just don't let things run wild. If they did there would be no reason to throw codes associated w/ O2 sensors.
Does all this need to be understood to tune a bike with these devices. 90% of the time. I would say no. But when things aren't going as planned. The better understanding of what is all going on will never hurt.
Old Aug 17, 2016 | 07:07 PM
  #217
Gordon61's Avatar
Gordon61
Just to go back to your why log kind of question
I'm dead chuffed with how mine is running in general but I have one small thingy left that (because I'm a really fussy and pedantic sod) I'd like to fix or at least know why it does it ...THAT is the only reason I'm still playing and running a few logs.
For me, logs are an analysis tool, rather than a reporting tool ...if that makes sense
Old Aug 18, 2016 | 03:00 PM
  #218
zigzag930's Avatar
zigzag930
Wow, so glad I found this thread. Finally getting some good insight on the ECM, add-on code, sampling, etc.
Old Aug 21, 2016 | 11:28 AM
  #219
Steve Cole's Avatar
Steve Cole
HD EFI Guru
Maybe, just maybe if you came here to contribute something you could learn something, but it seems your only reason for being in this thread is to try and start something. I've reviewed each of your post in this thread and none of them ask me to post something for you, regardless of what you have claimed. So unless you go back and edit a post to change it, your full of it. I do not ask anyone to post for me so you can drop all that as well. If you've got something to say spit it out otherwise go elsewhere as this is my last response to you.
Old Aug 21, 2016 | 11:58 AM
  #220
Steve Cole's Avatar
Steve Cole
HD EFI Guru
Gordon
Here is a little data that I recorded on a 2016 CVO with a 117 kit installed. One log is cold start and about 10 minutes of continuous idle. As you will see in the data it never went into EITMS as its a water cooled bike. This data runs about 18 fps. I then stopped the data and switch to a data collection that runs about 28 fps and got about 10 minutes more data. You can compare these two logs and see the differences between recording at different speeds and how the data appears to be different, yet it is the same data on the same bike. As for the bike I never turned it off, only switched the data and data rate between the two recordings. The two recording are recording different data but they both contain O2 sensor readings for you to compare as well as other things.
File Type: zip
