The Dyno Room A special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
DYNOJET: Cant open Power Vision map
Old Aug 10, 2016 | 05:54 PM
nick@nite's Avatar
nick@nite
Default Cant open Power Vision map
Dynojet sent me map in a email. i saved it to desktop. I opened winpv software found file. When i click on the file i get message says this item doesn't exist??? We tried over and over everyway we know to get this file to open didnt woirk. Dynojet says should be no problem everyone else does it. Wat a PITA!!!!!!
Old Aug 10, 2016 | 06:07 PM
Schex's Avatar
Schex
Did you run PV Update Client to see if everything is up to date?
Old Aug 10, 2016 | 06:27 PM
nick@nite's Avatar
nick@nite
No and no didn't know what that is. I give up I'm ok with computer and instructions but not tech savvy as you need to be to make this work. I followed the directions they sent me. When I hook up the PV to my computer all it says on the screen is: PC link is active: can't do anything with it.
I got the map they sent saved to desktop, I opened the WinPV software, I found the map, I connected the PV to the computer. The PV says - PC link is active- there's no way to get the map?
Old Aug 10, 2016 | 08:40 PM
WVDevil's Avatar
WVDevil
The WinPV update tool should be installed; run it.
Old Aug 10, 2016 | 10:46 PM
IKnowNot's Avatar
IKnowNot
Map on desktop must be loaded into WinPV first, then saved to the PV using “Send Tune”
Make sure you actually saved the map to the desktop, and that what you see on the desktop isn't just a link to the file. Also, make sure it isn't zipped … should have a .pvt extension.
As far as updates, I believe the new versions of WinPV now have, under the Setup Tab, a “check for Updates” that will launch the update client.
Old Aug 11, 2016 | 04:24 AM
nick@nite's Avatar
nick@nite
Yeah I gave up we did as much as we could . I'm not that tech savvy . I have no idea if the file is a extension or wtf it is. I did what dynojet said it didn't work. These PV are great so long as your very very very tech savvy otherwise what's the point?
Old Aug 11, 2016 | 05:49 AM
Schex's Avatar
Schex
Don't give up, your in the right place for help.
"PC link mode active" when the PV is connected to your computer, that's correct, that is all it suppose to say.
The PV doesn't have to be connected to your computer to get the tune loaded into WinPV.
Try the Update client first,
Go to "all programs" on your computer and look for powervision, click on it,
in the drop down list you should see "pv update client", click on it, "program needs you permission to continue" box should come up hit continue,
connect your PV to your computer,
you will see what is installed and the latest versions available,
click on lines that doesn't match, hit download and install.
DJ has instruction videos too.
Old Aug 11, 2016 | 06:00 AM
Schex's Avatar
Schex
After updates are done, if winpv was open, close it then open it again(just in case it needs restart for updates, not sure)
Hit open at top left, look for the tune on desktop, or where ever it's saved, click it, hit open, and it should load into Winpv
To send it to your PV, connect PV to your PC, have the tune loaded in Winpv, and hit "send tune"
Old Aug 12, 2016 | 05:18 AM
nick@nite's Avatar
nick@nite
Thanks we tried all that still no go. Thanks really for all your help I'm going to Dyno Thursday. The guy is a big PV guy not gonna rape me $$$. The last time I did this myself with a PC3 I sent wrong tune to my bike and screwed it all up. Like I said you really have to be tech savvy. Give me any type of carb and no problem in a cage or bike. Thanks again why I've been here since 06 great forum.
Old Aug 12, 2016 | 11:08 AM
Gordon61's Avatar
Gordon61
When you run WinPV, and then click "Open", the dialog box only looks for .pvt files so would not show you a windup/compressed file.
If you did change the "Files of type" option at the bottom of the open file dialog box and tried to open a windup/compressed file, it would say Invalid tune Filename Extension ...so I doubt it is that.
If the file was corrupt it would either say Cannot Load and, not a PVT file or Unsupported PVT version
An item does not exist error sounds like when you log on to your computer to run the WinPV software, that user logon does not have permission to open the file - how good were you with computers? does that make sense? Do you use email and WinPV using the same computer logon name?
