No Device: HD/Delphi EFI Tuning - EITMS
When EITMS kicks in the engine certainly feels and sounds very different and from the gauges I can see idle rise about 100rpm or so, the Rear O2 voltage drops to 0v and the idle is actually smoother
Steve mentioned the Integrators but looking at the log, I'm not sure if they are relevant here, it looks as if the ECU has increased the injector plus widths directly.
The other obvious question, if the rear cylinder is supposed to be dead, and sat on the bike it certainly feels like that is the case, where is all that fuel going? we're not washing the rear cylinder down are we?
can you tell us if the HD/Delphi strategy for EITMS is to actually cut the fuel to the rear cylinder (regardless of what logs say or not) or if that may be replaced by the third party tuning device/map?
Despite what the log says it's quite obvious the fuel is turned off.
Which makes me wonder...
If I were to set the EITMS on temp for lets say 200 F how much would I save on fuel at stoplights?
