The Dyno RoomA special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
I recently changed my air cleaner from a DK custom outlaw to a S&S tear drop air cleaner. I ran five auto tune runs and the VE tables changed very little. Now I have knock in the cruise range(3000 to 3200 rpm and around 45 kpa map). If I let off or give it gas it goes away. Only does it with steady throttle. I am not hearing it. I am seeing it pull timing with the PV. Up to 8 degrees. I changed the plugs and wires. Does the same thing. Would just changing the air cleaner cause this? Wanted to check before I change my spark tables. Thanks!
