The Dyno Room A special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
TTS: Milwaukee 8 Testing
Old Aug 30, 2016 | 01:08 PM
  #31
scooterbum46's Avatar
scooterbum46
Steve: There's an interview on the Baggers magazine website with a couple of HD people. In discussing the new engine one of them states that it's now a "torque based ECM". I can only assume that means a big flat torque curve is the priority over horsepower, but in trying to understand how this is achieved ... any thoughts?
Old Aug 30, 2016 | 01:23 PM
  #32
Wide Open Cycles's Avatar
Wide Open Cycles
Former Sponsor
Torque Managed tables are used instead of VE tables. There needs to be a
"switch" put in the new calibrations that will allow us to use VE tables as far as tuning is concerned. Most of the automotive industry uses torgqu managed calibrations and not VE calibrations. Hopefully Steve will be able to get more in-depth.
Old Aug 30, 2016 | 06:07 PM
  #33
scooterbum46
Thanks - googling now to see if I can gain insight, hope to learn how the tables are derived...
Old Aug 30, 2016 | 06:21 PM
  #34
Steve Cole's Avatar
Steve Cole
HD EFI Guru
Torque based is how automotive ECM's have been done for years. In basic terms it means that the pedal or twist grip in the case of a HD request from the ECM for an amount of torque to be delivered from the engine. The ECM then determines how to do it. One of the biggest reasons for doing this is that it allows for many other items to request torque to be raised or lower, to aid the power application. In the case of ABS brakes if it sense's wheel slip the ABS can request torque to be lowered until the slip is gone. If the BCM see's too much torque it may request it to be lower for the clutch and so on. Traction control is another big user of torque controls. So there are many things that come into play and tuning will be forever changed in th eHD world if the tuner have to learn to work with it, as it is now. We are working on it so the calibrations we create will allow the same old way of tuning to be used, but rest assured that may not last forever. So people (tuners) are going to have to get smarter and more test equipment will be needed to operate and tune torque based systems in the future.
Old Aug 30, 2016 | 06:40 PM
  #35
scooterbum46
Thanks for taking time out to answer this, Steve. I'm currently searching using " torque based ECM control theory" and have found some papers that describe in general theory what you just outlined . Again, thanks!
edit.. my first reaction on looking at some of the papers is " Oops - there goes the current way of re-tuning, unless you've got an engine lab in your back pocket..."
Old Aug 30, 2016 | 07:48 PM
  #36
Just Nick's Avatar
Just Nick
Steve are you going to offer Torque based tuning for us tuners that want to learn it and be ahead of the curve?
Old Aug 30, 2016 | 11:51 PM
  #37
Max Headflow's Avatar
Max Headflow
Funny.. You don't need a engine lab.. Just another level of software..
I'm sure Steve is up to it.. You'll a dyno and someone to load the bike and push the start button..
Old Aug 31, 2016 | 06:45 AM
  #38
Wide Open Cycles
Former Sponsor
Torque managed is a completely different theory of tuning. Is all mathematics. For now there needs to be a Switch built into the calibration to open up VE tables. As,long as,people like Steve are able to build in the switches things will be business as usual. If that ability go away all bets are off. HD has, the switches built into the SEPST and ST calibrations for the 17 models but the stock calibrations are torque based
Old Aug 31, 2016 | 11:19 AM
  #39
Steve Cole's Avatar
Steve Cole
HD EFI Guru
Just for the record, there is a team of people here at TTS that make all this possible. Each of us play our part in getting the software done. It's not a one man show and I do it all that is for sure. We keep working at improving what we already have to try and keep things as simple as we can for it to be used.
Old Aug 31, 2016 | 11:38 AM
  #40
Gordon61's Avatar
Gordon61
I don't mean to put a damper on things but
Originally Posted by Just Nick
ahead of the curve?
when
And there is or we want a switch in the calibration so that we can retrograde the latest and greatest back to the old way that we know ...kinda like chucking a carb on because we don't know EFI ??
I've never seen a definitive answer to whether MAP based VE table modelling was better than TPS based VE modelling ...now we are getting torque base modelling
If it's good enough for F1 cars then I'll have that please
But this is likely to shoot DIY tuning out of the water unless people start developing generic maps (like the stock ones), or a Dyno is involved to map the actual torque curves presumably ??
