The Dyno Room A special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
HARLEY: Tuning in Closed Loop
Old Oct 7, 2016 | 08:37 AM
Sergeich's Avatar
Sergeich
Default Tuning in Closed Loop
Hi everyone,
I've looked through the forum and couldn't find any information on closed loop tuning.
My bike is 2011 Wide Glide with EFI and O2 sensors. I've installed Stage III kit on it + exhaust and air filter. I also reprogrammed the ECU with SEPST with the closest matching map I could find there. But these pre-loaded maps are not final as I understand. Rather, they ensure proper engine operation with given hardware but require some further fine tuning.
So my bike runs in Closed Loop and I intend to leave it this way. I see no point in disabling the sophisticated self-correcting mechanism.
Some tuners do the following: they put the bike in open loop, change the values in AFR tables, change VE tables and flip the bike back to Closed Loop. But is doesn't work this way, because now the ECU will always try to remove fuel to get back to 14.6 AFR. So the result of this "tuning" is overly rich map and less mileage than stock. Correct me if I am wrong, that's how I see it.
Hence the question - how to tune in Closed Loop? The main thing is to get VE tables correct, right? But in Closed Loop the underlying base map needs to be set to differing air-fuel ratios. So far I am confused and would appreciate any knowlegeable input from forum members regarding the logic and general procedure for tuning in Closed Loop.
Old Oct 7, 2016 | 05:27 PM
RG Pilot's Avatar
RG Pilot
The way I understand it is to get your VE tables correct first by doing an auto tune. Once that's established then you can adjust your AFR from there and it'll be more accurate because of the correct VE's at each kPa and RPM. The problem though is the narrow band O2 sensors as they will only recognize a small window of AFR; something like 13.9 to 14.6 (I'd have to go back and check those numbers to be sure). Anything beyond those AFR settings will put you in open loop.
Old Oct 8, 2016 | 12:42 AM
Oz Nightrain's Avatar
Oz Nightrain
https://www.rbracing-rsr.com/downloads/tts_tuning.pdf
Have a good read of this, it should clear up a lot of your questions. It's a very comprehensive guide.
'06 NT, 95", S&S .510g, V&H BR 2-2, K&N AC, P&P Heads
Old Oct 8, 2016 | 08:13 AM
Ed Ramberger's Avatar
Ed Ramberger
Use the smart tune feature of the SEPST to adjust your VE tables. When done, set the AF back to factory if those are the settings you want.
Personally if you want to stay in closed loop, I would run the AF values to the low end of the closed loop threshold (14.3)
Mr. Wizard
The Dyno Room
146
Sep 28, 2016 05:30 PM
oleboy
19
Apr 4, 2016 08:09 PM
RK14SGS
May 19, 2011 08:44 PM
marty442
Exhaust System Topics
Jan 14, 2011 05:55 PM
ubreal
Mar 22, 2009 10:06 AM
