DYNOJET: Power Vision Headache
Thanks for that info.
I just downloaded it from the PV and although I set it to save it as a csv file in PV it's a pvv file. I'm going out of town until Wed. so I'll have to fiqure out the file save thing and post it then.
See page 11 of the Auto Tune doc.
You sound as if you have covered this off already but just to outline...
Setup the logging to collect some useful information - From the starting menu...
- Datalog
- Datalog Settings
- Signals
- Auto (Narrowband Tuning), Select, Continue
- Back
- Guages
Use left and right to display one of the 6 position displays.
- Tap on one of the positions
- Signal
- Vehicle
- Move up and down to select "Front O2 Sensor Voltage", OK, OK
- Repeat to set "Rear O2 Voltage" in another position
Go for a ride, get bike hot, then Tap Start Log, 5 mins or so, then tap End Log
Then WinPV to extract the Log000x.csv
The .pvv files are an autotune settings file rather than a log file.
If you want to log the autotune session - When in Autotune, use the mode button to get to the Hits screen (if not already there). There is a Start Log button at the bottom.
Free up some memory and clean things up at the same time, delete them from the PV, you do not need them.
As Gordon61 said they are created by the PV when using the AutoTune function. The PV then uses the information in the file to calculate the new tune. Once the tune has been saved to the PV that file will not be used again, it will create a new one next time AutoTune is run.
Again I want to thank everyone, the help around here is great. This is how someone learns how to do things correctly.
Ensure the engine is fully warm prior to starting a data recording
Ride the motorcycle at many different engine speeds and throttle positions.
Perform some constant speed runs at a stable throttle position in multiple gears.
Perform some increasing speed runs at a steady throttle position in multiple gears.
If large corrections are needed to a calibration, multiple data collections and calibration updates are required to ensure a proper calibration.
While recording data, ride at 5 mph increments from idle (low engine speed) to maximum engine speed or a safe vehicle speed for track conditions in all gears. Hold constant speed for 5–10 seconds at each speed/gear combination.
To fine tune the drivability region of the calibration, perform data recording under normal operation.
While recording data, perform multiple wide open throttle acceleration runs from 2500 rpm until maximum engine speed or a safe vehicle speed in 2nd through 6th gears.
Repeat the data recording process and calibration processing several times to attain a proper calibration.
It is not necessary to record data higher than 80% throttle.
Logging for the purposes of tuning manually (rather than the autotune) is something else altogether.
