The Dyno RoomA special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
looking for a base map for my new 117" twin cam build with s&s 570 cam, 58mm throttle body, 5.3 injectors, and 2-1 dragula exhaust. i've done a few tunes on this bike back when it was a 103", but have no base maps for v-tune on this new build.
The 2 most important influences on how an engine will breathe is valve timing and exhaust design.
Find a calibration (ie: 103ci) for an S&S570 with a Dragula, D&D Fatcat, Bassani B4, etc. (long primary pipes)
Set the cal for 125ci and 5.3inj.
Use that as a tuning base.
Good luck,
Bob
Good luck,
Bob
my last tune was done on my bike with the same dragula pipe and dragos 580 cam. i think the S&S 570 cam is similar to the dragos 580 cam. intake timing seems similar, exhaust timing is a little different.
you think i could just use my old file, change the ci to 117 and injectors to 5.3, then do vtune?
