The Dyno Room A special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
DYNOJET: Dynojet stack
Old Feb 9, 2019 | 11:25 AM
dynodon's Avatar
dynodon
Default Dynojet stack
Is there anybody that can just put a battery in my dynojet stack
Old Feb 9, 2019 | 11:55 AM
FLTRI17's Avatar
FLTRI17
Which stack are you referring to? The original or the latest?
Bob
Old Feb 10, 2019 | 09:15 AM
dynodon's Avatar
dynodon
Bob
its. The Original with the wenpep 7.? I've sent in 2 times for updates and its due for a battery
Old Feb 11, 2019 | 03:36 PM
hrdtail78's Avatar
hrdtail78
A replacement battery can be found on Amazon. Replacing the battery is easy. If you do it fast enough while the other battery is good. You might not loose filmware. If you remove battery and loose filmware. It has to go to dynojet because I don't know of any other place that can download the filmware. Here is a PDF
Old Feb 11, 2019 | 03:40 PM
hrdtail78's Avatar
hrdtail78
The PDF is a bit bigger than this forum will allow me to post. Send me your email and I will get it to you if you want it.
Old Feb 12, 2019 | 11:48 AM
dynodon's Avatar
dynodon
harleyfxdx@sbcglobal.net
Old Feb 14, 2019 | 12:19 PM
dynodon's Avatar
dynodon
There is no sending them back to dynojet after 01/01/2019 they do no more repairs now I'm going to get a battery and try it if I dont make it will just cost $2500 no big deal lol wish somebody had the firmware to be flasted
Old Feb 16, 2019 | 07:38 PM
hrdtail78's Avatar
hrdtail78
Talked to DJ at a show today. I brought up releasing the film ware. They laughed and said it wasn't going to happen, ever.
Old Dec 23, 2019 | 12:28 PM
FXRFXR's Avatar
FXRFXR
Stage II
hrdtail78,
I have an old DynoJet 150 and would like to replace the battery in the hardware stack before it dies. I'd appreciate it if you could email the PDF file that you have for instructions on how to do it. I sent you an email.
Old Dec 24, 2019 | 01:18 PM
marcodarq's Avatar
marcodarq
when you remove the battery......before total disconnection at each terminal attach a jumper wire to a fully charged battery,, then remove from the battery you are replacing, keeping the jumpers in place, then re-attach new battery and remove jumpers. if done carefully, there should be no voltage loss and no firmware issues.
m
