The Dyno RoomA special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
not sure about the comparing edits to baseline and edits to original options
I assume original is the original TTS calibration programmed into the ecm
baseline was the previous calibration ?
I have the 'compare edits to baseline ' ok
I have all zeros for 'compare edits to original' ?
Am I able to view the differences between the current calibration and the starting TTS calibrationin to assess the changes derived from vtune
particularly interested in timing
Thanks
original is the TTS one you started with. Baseline/working is the one you are looking at now without any edits. as soon as you make an edit in the one you are looking at now, that version becomes the working, the baseline is without the edits.
Compare edits to original is all your changes up to now from the starting TTS calibration.
Yes
that is my understanding
why does my 'compare edits to original' have all zeros ?
