The Dyno RoomA special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
Running an auto tune on a '20 LRS and Power Vision got a fair number of cell hits, but then about 10 min into the session it started showing NB:O on screen, which is narrow band open loop, which doesn't make sense while the PV is in auto tune mode. Engine was hot, and as said had already captured a fair amount of cells. Any idea what I can look at?
This is a FuelMoto tune, but they are closed until Mon and I was hoping to get a few sessions in tomorrow, during the completely unexpected 60 deg weather we are having today and tomorrow...
I would make a copy of the map from FM in WinPv, manually set the afr to .981 or .984 across the board, and try that. Just make sure you name the copied map different than than the original FM map.
Thanks for the reply
But I thought that when running auto tune, the PV sets the entire afr table to 14.6 (or something like that) so the NB o2 sensors can accurately record VE values, essentially making the AFR table insignificant during the auto tune process? Autotune is essentially only changing VE tables and spark to eliminating any knock, right?
