The Dyno Room A special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
TTS: Baseline map for RS527 Cam
Old Jan 24, 2020 | 07:58 PM
Stoney Lawson's Avatar
Stoney Lawson
Default Baseline map for RS527 Cam
hey guys just got a redshift 527 cam installed, does anyone have a baseline map for this cam? 103 stock btw!
Thanks for any help, even if it'll get me close enough to get to a dyno.
Old Jan 24, 2020 | 09:15 PM
marcodarq's Avatar
marcodarq
Year, model, exhaust systemand other mod info is needed.
m
Old Jan 24, 2020 | 09:30 PM
Stoney Lawson
2012 Fatboy Lo 103
Rinehart staggered duals
screaming eagle heavy breather
Old Jan 25, 2020 | 06:54 AM
marcodarq's Avatar
marcodarq
What tuning product?
m
Old Jan 25, 2020 | 06:56 AM
Stoney Lawson
m
TTS sir
Old Jan 25, 2020 | 11:23 AM
marcodarq's Avatar
marcodarq
Doooah, my bad, i should havve caught that from the title....where in florida are you?
m
Old Jan 25, 2020 | 11:36 AM
marcodarq's Avatar
marcodarq
after looking in the TTS calibrations book, you might try DAC358-03, it for TW37 cams and true dual exhaust so it's not something that i would run full time but it should allow the bike to run in order for you to take it in and get it properly tuned. the timing numbers on the cams are very close. AGAIN this is just to get it to run not for regular riding.
m
if you look through the V-Tune book, the info there can help you get a baseline that has your cam timing events dialed in, but there is a ton of info in the instructions.
m
T Prescott
Vance & Hines
Sep 24, 2018 08:03 PM
dochawken
Mar 26, 2014 09:09 AM
Mikiedice
May 3, 2013 01:28 PM
skully1200
Aug 6, 2011 03:52 PM
SC-Longhair
Apr 27, 2010 01:53 PM
