Front shimmy
Old Sep 25, 2014 | 10:56 PM
xpilot's Avatar
xpilot
Default Front shimmy
Just threw my tourpak back on after the summer without it. As I was coasting and slowing down for a stoplight, the front starts to wobble side to side. Reminds me exactly of my old Goldwing. I only had one hand on the bars, and was able to stop it right away. So.... I try to make it happen again, and it does. I am due for new tires, and wonder if there are better tires than the stock dunlops (which I think as they wear cause some of this). Also, is it more pronounced with the extra weight of the tourpak on the rear?
2003 flhtci, 37k on it.
Old Sep 25, 2014 | 10:58 PM
gartec81's Avatar
gartec81
find out what mph range it happens at.
see it it also happens while excelerating at the same speed
if you hold it at that speed does the wiggle continue
i would say neck bearing need to adjusted
Old Sep 26, 2014 | 07:07 AM
grbrown's Avatar
grbrown
There are plenty of better tyres, all the major brands make suitable ones. My own favourites are Avons. If you need tyres I suggest you have them fitted, whatever you chose, then repeat the conditions to see if your bike still does it. If you do change brands check their website to ensure you use the correct pressures, as some brands use different psi to the handbook, including Avon.
Old Sep 26, 2014 | 10:14 AM
Hogpro's Avatar
Hogpro
Former Sponsor
Steering head bearings need to be greased and tightened and I'll bet a new different brand tire will also make a world of difference. Try a Metzeler ME888 or Michelin Commander II and open up a whole new world of handling abilities for that bike. I'd also check the tire pressure on those tires.
Old Sep 26, 2014 | 10:27 AM
KCFLHRC's Avatar
KCFLHRC
+1 on the Michelin Commander II's, they are incredible tires and will wear as well if not better than the Dunny's.
Old Sep 26, 2014 | 11:50 AM
UUNetBill's Avatar
UUNetBill
+2 on the Michelins - I just installed a set last night and my ride in to work today was like being on a new bike. Rides better, handles better, smoother, quieter, and no more wandering on grooved pavement. Now granted, a lot of that may be the difference between new and old tires, but I don't remember the stock Dunlops being this nice even when they were new...
Old Sep 26, 2014 | 11:59 AM
Hogpro's Avatar
Hogpro
Former Sponsor
They really do handle that much better than stock tires.
Old Sep 26, 2014 | 09:50 PM
xpilot's Avatar
xpilot
Neck bearings have been greased and checked. Front tire seems to have some odd cupping to it. Like I have said, I have seen this before with these tires. End of season is near. Time for tires of a different tread pattern when it is down for the winter.
Old Sep 27, 2014 | 07:42 AM
btsom's Avatar
btsom
Load rating is critical, make certain it is within a few pounds of the same as the Harley specified tires.
Old Sep 27, 2014 | 10:47 AM
Just Me's Avatar
Just Me
Haven't owned a Harley that didn't do it at one time or another including my new 14 Ultra.
