If you're that worried about it and felt compelled to post yet another thread on this topic, you should of ordered the thing and left your ride parked in the garage until you felt it was safe to ride.
Just to put it in perspective, with well over one million HD touring bikes on tbe roads worldwide since 1979 with this mount system how many fatalities have been attributed by accident investigators to this issue?
Yeah I do. You could feel the flex, twisting of the bike at the triple tree or steering neck area, right at the dip in the road and resonating after while wobbling. It's a pucker moment for sure!
The pre '14 FL's have been using the same undersized 41mm front fork tubes and non clamping top triple tree design since the 40's I believe. The top tree does not clamp down on the fork tubes they merely guided the tubes allowing flex to occur. The bottom triple tree was clamped and the fork tubes can and will flex, or twist, at the bottom tree clamping point. Simple physics.
The forks are allowed to flex while riding from a front to rear motion. If you mounted LED lighting strips on the side of your fork tubes and film it from another bike while riding you would be surprised at how much they can and do flex from front to back. The design has been due for an overhaul for many years.
Riders today ride on much improved Interstates at far greater speeds than they did back then when this was designed years and years ago. The front end wobble is just one of several ways a wobble can be introduced. And riding aggressively can create a scenario that increases that possibility. If you were to ride passively and never push your bike to its capabilities you may never experience any wobble of any kind. Other than low tire pressure most all of the reasons for the wobble is due to a twisting motion being induced. That's why they are usually always while in a curve of some kind.
On a '14 and up Rushmore you can feel the stiffness or rigidity of the larger fork tubes right away. And hitting that very same dip in the very same sweeper at even greater speeds I didn't feel any flex or twisting in the front end at all. The bike felt like a solid entity just cutting through the corner.
The old top tree is indeed a serious flaw in the older bikes, although there is a solution available, courtesy CCE. The larger diameter fork tubes in the later bikes is a bonus and progresses the forks into the 21st Century. On older bikes, once a rider has addressed the rear end wobble the forks are a natural next step towards nirvana.
While the newer forks have less twist and flex due to the bigger tubes, I doubt that they are that close to the root cause for the high speed wobble.. For instance my 07 is rock solid with the right tires anything up to over 100 mph.. It still has the older frame and 41 mm forks.. Fer sure the steering is not as precise as the newer 49mm tubes.. but there are issues with the newer forks that HD missed when they made the change.. For one they should have used pinch bolts on both sides of the fork axle. Second when the redesigned the trees, they should have placed the steering bearing adjustment on the lower tree not the top.. That way you wouldn't have to remove any covers to adjust the steering bearings.. It also looks like they gave up the 2 speed compression damping system and went back to a single speed system.. One thing they did do right is up front rim diameter and go to a 130/60 tire on the SGs.. IMO most of the front squirm is in the front tire... Carcass, tread flex and tire is a big issue and one one the major contributing factors to the stability on the 09 up frames.. All this stiff needs to be matched. Its' good to see HD narrowing in on it.. It helps to make a safer bike for those who don't understand all the issues.
Well passing a big-rig is a WHOLE different story. Almost any rider has experienced that, especially with any kind of cross breeze. When passing, twist the wick, and hold on.
Wasn't worried about it, just asked if this was even an issue with the newer models. Sorry, some of us aren't all knowing like others on here.
On my ride home from work, I take a long, high-speed right hand sweeper (ramp from one interstate to another) that never caused me any problems. A few months ago, I started to get a 'wallow' or maybe even a 'wobble' depending on your definition - but only on that one particular sweeper. I'd get a little froggy on some others, but nothing serious...
And yes, tire pressures were fine.
Turns out the tires weren't. Stock Dunlops, rear was pretty badly cupped. Slapped on a new set of Michelins and all is right with the world again.
