air shocks
Old Apr 10, 2007 | 10:18 PM
wessscott's Avatar
wessscott
Stage II
Default air shocks
How and why do you adjust the air on an 07 Elctra glide classic? I need my bike to be a little lower, can I get this by letting air out?
Wess
Old Apr 10, 2007 | 10:28 PM
fatboylust's Avatar
fatboylust
Default RE: air shocks
Not so much, the air make a difference in the load capacity but very little if any change in the ride hight. There is an air valve between the left saddlebag and the fender near the rear saddlebag mounting bracket. As for the height issue you may want to look at a reduced reach seat to get an inch or so closer to the ground and there are shorter rear shocks like those on the Street Glide and Road King Custom.
FBL
Old Apr 10, 2007 | 10:36 PM
Panhead_1_9_4_8's Avatar
Panhead_1_9_4_8
ORIGINAL: wessscott
Wess
Air doesn't make much of a difference. You'll need to get shorter shocks. FYI ... if you mess with the air ... don't go at it with a regular compressor unless you have it dialed way down.
Old Apr 11, 2007 | 12:19 AM
schoney's Avatar
schoney
I took the air out of my 99 flhpi front and dropped it an inch. I put plug in place of the air lines. I took off my rear shocks and replaced with a one inch lower rear shock from the local hd shop. works great for me. The air in the front only stiffed the front but won't adjust height. Don't put more than 10-15 psi in them.
St Glide
Apr 16, 2019 09:36 AM
dallas333
Aug 15, 2018 06:57 AM
biker47
Mar 10, 2013 02:20 PM
berndog
Oct 26, 2012 04:49 PM
Billdoe
Feb 20, 2011 11:39 AM
