07 Electra Glide Air Shock Issue
Old Feb 9, 2011 | 12:18 PM
Billdoe's Avatar
Billdoe
Default 07 Electra Glide Air Shock Issue
i have a 07 Electra.. i swapped out the wheels to a 21 front and an 18 rear and then installed a 2 inch lowering spring kit in the front shocks and bought a set ofd rear air shocks for a Street Glide which are suppose to be 1 inch lower then the stock Electra shocks.. problem is they came oil filled and when i put my Air Lines with fitting on the new shocks.... they will not air up.. i took the lines out and air does travel thru the lines but does not air the shocks up.. so i can not put any amount of Air in the shocks, like there is a plug inside the shock so no air enters them.. i need to correct the problewm cause of handling issues. i need to stiffen thew rear up so in turns it doesnt start doing the hop (walking into other lane) as you turn.. if anyone has ran into this problem let me know.. the air shocks i bought were new Chrome lowering shocks.. my luck i got bad set or there is something inside the shock blocking the air .. I DON'T KNOW
Old Feb 9, 2011 | 12:51 PM
albngore's Avatar
albngore
You say the shocks are new but I wonder if they were put together by an aftermarket outfit. Reason I ask is that if there is way too much oil in the shocks then there would be no place for the air to go. At least I believe this is true from what I have read on HDF. It is also possible of course that the air valves to which you have affixed your pump are faulty and losing the air as fast as you are pumping it in. Likely you would have noticed though if that were the case.
Old Feb 9, 2011 | 01:25 PM
Billdoe's Avatar
Billdoe
the shocks are used but newly chromed and filled with Oil. i think they me over filled with oil ..... cause its like the air will not flow into the shocks like there is no room for air.. i know it does NOT Leak air. i caN TELL NO AIR GOES IN WHEN I TRY N FILL IT. . gonna stop by local harley shop and see if thats whats going on. .
Old Feb 9, 2011 | 01:31 PM
albngore's Avatar
albngore
Yep. Overfilled with oil.
Old Feb 20, 2011 | 11:39 AM
Billdoe's Avatar
Billdoe
fixed them. guy i got them from put rubber plugs down inside where the air fitting goes. had to dig the plugs out. once got them out they accepted air and work fine now
mikeboztx
Nov 23, 2020 09:35 AM
bigpappa160
Oct 28, 2018 07:03 PM
berndog
Oct 26, 2012 04:49 PM
supr_glde
Jun 14, 2011 06:55 PM
O5HOG
Jun 11, 2006 12:02 PM
