Radio intercom issues
Old Oct 8, 2014 | 09:07 PM
Pepsi62011's Avatar
Pepsi62011
Stage I
Default Radio intercom issues
When I have the intercom on I get a lot of noise in the headphones. I will loose radio station with the constant interruption from the headphones. If I use the speakers or headphones for radio only everything is fine. Only when I try to use the intercom does things go wrong.
Old Oct 8, 2014 | 09:23 PM
Weavr99FLHT's Avatar
Weavr99FLHT
Adjust the VOX setting - sounds like your mics are picking up too much ambient noise and cutting in.
Old Oct 8, 2014 | 10:08 PM
dwoodlives's Avatar
dwoodlives
I experienced the same problem. We are using the H-D helmet speakers. I could never find an adjustment of the VOX that would allow the intercom to work without yelling that would also not allow outside noises [wind, other vehicles, etc.] to trip it.
I finally gave up. When my lady and I ride now I have the VOX turned up all the way so that it is constantly open and allows us to communicate using normal voices.
The downside [actually I don't consider it a downside] is that with the VOX this way you cannot use the radio/stereo as it take precedence over them. However, if you are using the blue tooth with your phone, it DOES override the VOX and you can receive phone calls. This [to me] is a necessary thing.
We both enjoy the 'quiet' just being outside in the breeze. At the same time if something of importance needs to be said, that is instantly available.
Old Oct 9, 2014 | 05:37 AM
Weavr99FLHT
make sure the microphone is facing the correct way (your mouth). You can put a thicker wind-sock on the mic to reduce the affect of wind. you can replace the HD Microphones (they crap out a lot). If you replace with aftermarket, replace both of them - I've seen mis-matched microphones cause issues due to different sensitivity. you can turn off VOX and use PTT but if CB is on, you will broadcast your conversations over the CB. the Intercom has separate volume setting. Many settings you can play with until you get it right for you.
I have found not having the intercom is less stressful - my wife will choose the worst times to ask stupid questions - one time, in the midst of bumper to bumper rush hour on a 3-laner, I needed to change from right lane to left lane to take a left side exit, no one was letting me over because everyone in a hurry, and in the midst of it all, in my helmet I hear "did you put the mail on the kitchen table?" -
Old Oct 11, 2014 | 07:39 AM
Onetrackmind's Avatar
Onetrackmind
We had the same issue, wind noise would turn on my wife's mic at a lower Vox setting than her voice would. We realized later that the PTT button also works for the intercom, so we just turned the Vox down and used the buttons.
Old Oct 11, 2014 | 08:44 AM
Boomer1143's Avatar
Boomer1143
+1
Old Oct 11, 2014 | 08:59 AM
sunderhill's Avatar
sunderhill
I read this to my wife and we both cracked up laughing. Thanks for the laugh as it sounds just like the 2 of us.
Old Nov 8, 2014 | 07:34 PM
really's Avatar
really
1st Gear
Forget it
Old Nov 9, 2014 | 07:11 PM
slapshot12's Avatar
slapshot12
That would be my guess too. On my '11, we just used the PTT buttons since the CB was always off. On the '15, I was actually to adjust the Vox and get it to work halfway decent with minimal wind interruptions.
Luckily, my wife doesn't chat much on the bike
Old Nov 9, 2014 | 08:22 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Wind and/or ambient noise is tripping your vox. You can try reducung vox sensitivity, but to prevent the tripping, you may have to turn it so low that it will not work when intended.
Best solution is to use the ptt button if u cant solve that aggravating tripping. Turn off the cb if u are not using it since the ptt will key the cb transmitter as well.
