Thinking about getting the Daymaker
Old Oct 15, 2014 | 11:27 AM
Aversocki's Avatar
Aversocki
I just got the daymaker reflector and it is far and away worth the money. I also ordered mine from Kutter.
Old Oct 15, 2014 | 11:30 AM
96roadking's Avatar
96roadking
You could also check out Kuryakyn phase 7's. I put on the head light and passing lights and they have a trick little gizmo that allows passing lamps to be on with high beams.
Old Oct 15, 2014 | 11:41 AM
Road Star's Avatar
Road Star
Any special connector required?
Do they bolt up the same, with the same chrome trim ring?
Old Oct 15, 2014 | 11:50 AM
gipper's Avatar
gipper
Originally Posted by Road Star
So, the reflector style is better than the projector style?
Night and day difference....pardon the pun.
Old Oct 15, 2014 | 11:57 AM
UltraNutZ's Avatar
UltraNutZ
I agree. I've had both on my batwing.. the original daymaker and their matching passing lamps lasted 1 weekend and just as nchogan pointed out; Took the bike out in the hill country and discovered very quickly it's a narrow projected beam that angles to the ditch and to the sky when leaning into a curve leaving not much light in front of you. Anyone that rides the hill country knows that's a recipe for disaster with axis deer all over the place. Now Roadies for some reason are different because of the dual headlight setup and those things are bright as hell and flood light in a different manner. I pulled it, sold it, put my Sylvania UltraStar setup back in with no further intention to do it again. Then along comes the Reflector model.. Been running it and the passing lamps for almost 2 years now.. love it!
Old Oct 15, 2014 | 01:38 PM
rbferg's Avatar
rbferg
I also run the HD Reflector and agree, overall it's the best LED available now. The connector is the same (plug and play). It comes with a new mounting ring and uses the same trim ring.
Old Oct 15, 2014 | 01:39 PM
JONAS1969's Avatar
JONAS1969
I installed a set of these on my V-Rod NRSRG. I ride out here in the Texas hill country all the time at night and I wouldn't want to go back to the old setup.
Old Oct 15, 2014 | 02:05 PM
Road Star's Avatar
Road Star
Is the Truck Lite as good as the Daymaker? Same reflector style?
I heard that with the Truck Lite you cannot use our outer chrome trim ring on the nacelle.
Old Oct 15, 2014 | 02:28 PM
rbferg's Avatar
rbferg
The Truck-Lite 7 design is not quite as advanced as the HD Reflector and I've noticed poor daytime visibility at certain angles with the TL7. The HD Reflector can be seen very well from any angle. The TL7 also sticks out without using a "Frenched" trim ring, so HD Reflector looks allot better IMO.
Old Oct 15, 2014 | 04:22 PM
brihvac's Avatar
brihvac
Love my Daymaker's. Bought the auxiliary lights from a member here and the headlight from Kutter. I tried buying that one that Ultanutz posted but I have PM'ed that guy many times with a question and he talked around my question so I had a bad feeling about it and just bought new
