Question:
I took the stock 2 Up seat of my '05 RD Classic and want to install the La Perla Bare Bones Solo seat.
Apparently I need additional hardware to be able to get the screws to attach to the fender (see pics). I am nowhere near an HD dealership.
Could you tell me what I need to accomplish this?
I ran a Lepera solo on my 2000 Road King for a while. You have the correct brackets for the seat. The four small screws attach the brackets to the seat. What you are missing is the bolt kit that comes up through the fender. The large holes in the seat bracket sit down on these. That bolt kit is available through HD. I think I got mine with my Sundowner Solo as an extra cost kit. There are a variety of nuts available. Some accept passenger seats or luggage racks. I think this kit also comes with standard Harley sticker shock. Good luck.
Thank you!
Is it a pain to get the bolts through the fender?
Well I spent 6 hours in the car driving to two different dealerships. One had the bracket that goes underneath the fender and the other one had the nylon washers and bolts. It's beyond me why those white nylon washers are so large. It looks terrible.
I used fishing line to pull the bracket to the holes in the fender and it worked very well.
Just did the same thing to my RK Police over the weekend. The Police bikes come with the bolts because that's what holds the plastic panel down. It looks like it would be kind of difficult to pull those bolts through from below. I used to have to do this on my old Fatboy when switching between solo and 2 up seats.
Here's a pic of mine. So glad I made the jump from Softail to a Road King, such a different bike.
It went surprisingly well to get the plate and threads to come through the fender - probably because I took it real slow. I tied fishing line to the top of one of the threads. The most challenging part was to wiggle the plate inside between the fender and tire. I was able to get the one thread through one hole and was then able to manipulate the plate for the other thread/bolt to come through the other hole. I made sure I had the washers within arm's length
The big plastic washers hold the bolt kit from falling back through when you remove the nuts. I imagine you could get some smaller stainless washers and half nuts that would accomplish the same thing.
Yes, but I think they are also supposed to protect the paint/fender. I think I will just cut them smaller so that they will still protect the area where the nut will sit, but won't be as visible anymore.
