lowered front end
Old Oct 21, 2014 | 09:09 AM
RaceFace's Avatar
RaceFace
I did the Progressive Drop-In kit in mine too and went down 1.5". I originally did all SE oil and it rode way too firm. I changed it to a 50/50 mix of stock and SE and it's just right for me. I'm also running 12" air shocks in the rear and the rear is bumpier than the front, even with low air pressure. May try changing oil in the rears and see what happens. I've read here that its a huge difference.
Old Oct 21, 2014 | 09:13 AM
OldPhat's Avatar
OldPhat
When I had my 07 RK Custom I did lower the front 1 inch, and had no problems with it.
I also put on footboard extensions from V Twin Goodies, and when I reinstalled the footboards
I moved the front mount to the upper frame hole for a more comfortable angle. I also noticed
that once in a while the footboards would scrape in corners, but not vary often. when you
do lower your frontend it is a good time to drain fork oil and replace it with a high quality fork
oil like Belray 7 or 10 weight
Old Oct 21, 2014 | 10:00 AM
SafetyMan's Avatar
SafetyMan
Originally Posted by RKZen
I went with the HD Profile Lows and a seat mod when I got my RK. The shocks dropped front and rear 1" from stock....
What? I must have missed something.
You're saying that putting 12" shocks on the rear dropped the front 1"?
Actually going to HD Profile Low shocks only nets ž" at best, on the rear only.
Old Oct 21, 2014 | 10:03 AM
Weavr99FLHT's Avatar
Weavr99FLHT
Originally Posted by SafetyMan
What? I must have missed something. You're saying that putting 12" shocks on the rear dropped the front 1"? Actually going to HD Profile Low shocks only nets ž" at best, on the rear only.
HD sells profile low front suspension too
Old Oct 21, 2014 | 06:48 PM
2013superglideseattle's Avatar
Thanks guy!!! My next winter project is just that. Lowering front end and replacing my kick stand with a shorter one.
Old Oct 21, 2014 | 07:44 PM
SafetyMan's Avatar
SafetyMan
I know that. We put it in the wife's SG.
But that's not what he said...
Old Oct 21, 2014 | 09:47 PM
Groucho1's Avatar
Groucho1
Default ??
If you have the Progressive drop in unit. The oil isn't for damping, only to keep it lubed. Doesn't matter what kind of oil.
BTW...I wouldn't get the Progressive units again..Too stiff for my liking.
Originally Posted by bikerlaw
I bought the Progressive Drop In Kit. You can go anywhere from 1-2inches. I went 1 1/4 inch and added heavy fork oil. Looking back, I would have gone with a blend of half standard and half heavyweight oil, but I wanted to never have a bottoming out problem. I am very pleased with the fork drop in conjunction with the one inch drop in the rear.
Old Oct 21, 2014 | 11:32 PM
RKZen's Avatar
RKZen
You're right SafetyMan. The HD P&A says so, so it must be! All I know is it got me flat-footed.
Old Oct 22, 2014 | 04:07 AM
NELS's Avatar
NELS
'10 RK 1" lower mono tubes in ft. and 12" SG shocks in rear.Very harsh ride! Changed the rears to Ohlins and everything changed, smoothed out the front also. I don't understand why but am satisfied with the ride now.
Old Oct 22, 2014 | 06:00 AM
bikerlaw's Avatar
bikerlaw
Not sure what you mean??? The drop in kit is just a set of 2 shorter springs, two stabilizer springs, and cuttable spacers. The oil is critical is dampening.
I think all he was saying is the stock shocks are 12 3/4 inches, not the 13 inches we all are guilty of calling them. So swapping from stockers to the 12 inch Low Profile shocks will only net you 3/4 of an inch drop, not an inch.
