Inner primary main shaft seal
Old Oct 21, 2014 | 06:50 AM
Gordon65's Avatar
Gordon65
Default Inner primary main shaft seal
How difficult/complex is replacing the inner primary main shaft seal?
I've developed an oil leak, and I'm pretty sure this is the culprit.
complex job? need special tools?
I do have a manual, forgot to read this section last nite...
Thanks
Old Oct 21, 2014 | 06:55 AM
Jackie Paper's Avatar
Jackie Paper
Someone on here said if you start on the right side, is easier to get to? Not sure. Think it has to do with the bike leaning on the stand.
Old Oct 21, 2014 | 07:06 AM
shadowchrome's Avatar
shadowchrome
Well, you have to pull the clutch and compensator so you'll need the sockets for that, something to lock the primary chain with, loctite and a torque wrench for reassembly and I find an air impact really useful for removing the clutch and compensator!
Old Oct 21, 2014 | 07:07 AM
Greezey Rider's Avatar
Greezey Rider
Pretty straight forward job, no special tools needed. Remove the outer cover, pull the clutch, compensator and primary chain, remove the inner primary and pop in a new seal.
I'd replace the shifter shaft seal while I was in there....Then put it back together and go for a ride.
For someone that's familiar with the job it takes about 2 hours, for someone that's never done one, plan on 3 to 4 hours.
Old Oct 21, 2014 | 07:22 AM
Def Mute's Avatar
Def Mute
When you figure out why the magnets keep separating from your rotor, you will stop using that impact wrench on both the compensator and clutch nuts...
Get a strong breaker bar and a cheater pipe, works without causing harm.
Old Oct 21, 2014 | 08:43 AM
DHubbs's Avatar
DHubbs
YUP! Good advice. Read the manual, take your time, don't cut corners. These thangs aint rocket science, you can do it.
Old Oct 21, 2014 | 10:23 AM
aclass's Avatar
aclass
Once you've removed the inner primary, dont forget to check the race and make sure it hasnt walked toward the pulley. If so, all your hard work and new seals will be futile.
Old Oct 21, 2014 | 10:27 AM
Greezey Rider
Good advice, I usually just replace the whole mess with the Baker inner primary bearing set up, it's a much better design.
Old Oct 21, 2014 | 10:43 AM
cromagnon's Avatar
cromagnon
Check your belt and your final drive pulley teeth while your in there. If the pulley teeth are rounded off it will strip eventually. I've seen it happen to 2 friends while we were out on the road. Those guys ride hard though. They had to get picked up.
Incidentally, make sure you don't over tighten your belt. That can be a root cause of seal failure.
Old Oct 22, 2014 | 07:35 AM
Gordon65's Avatar
Gordon65
aw crap.....this may be self-inflicted then.....when I took the rear wheel off earlier this summer, I adjusted the belt tension per the manual (up on a lift). when the bike was back on the ground the belt felt a lot tighter, but since the manual said to adjust the tension on a lift, I left it....
