Cam tensioner replacement
Old Oct 24, 2014 | 08:46 PM
Rogue8Man's Avatar
Rogue8Man
Default Cam tensioner replacement
What is he average labor hours for a shop to replace the cam tensioner shoes on a 99 FLHRCI?
Is there anything else they should hit while in the cam chest.
TIA
Old Oct 24, 2014 | 09:41 PM
Retrop's Avatar
Retrop
New cam tensioners are about $40.00 each for front and rear. I would not think labor would be over 2 hours tops.
You would probably want to check to make sure the cam chains were not stretched out.
Old Oct 24, 2014 | 09:45 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
might consider cam bearings,a few years had questionable bearings.
Old Oct 24, 2014 | 09:57 PM
user 8373900's Avatar
user 8373900
2 hrs. not even close.. Tank comes off, top end to pull the pushrods, gaskets and O-rings, inner bearings, tensioners, He's going to spend 300.00 at a dealership.
Mark
Old Oct 25, 2014 | 06:45 AM
gilbos440rt's Avatar
gilbos440rt
The best bet is to go ahead and replace the one piece pushrods with adjustable ones, that way you won't have to pull the heads and it will more than pay for the pushrods IMHO ;-)
Old Oct 25, 2014 | 07:27 AM
Retrop's Avatar
Retrop
Mark
Use a bolt cutter to cut the OEM pushrods and then lift them out. Replace with adjustable pushrods which drop in place. By doing this you eliminate pulling the heads altogether, thus saving a ton of labor. I just did this a month ago so I know 2 hours is about right.
Old Oct 25, 2014 | 06:47 PM
navybuff's Avatar
navybuff
I just put an gear drive in my 04 Heritage, no more issues, no more chains, no more tensioners . Still need to do the push rods (adjustable) when you do this...
Old Oct 26, 2014 | 06:08 AM
Campy Roadie's Avatar
Campy Roadie
You don't have to pull the heads to take out push rods. Take off the upper rocker cover and remove the rocker arms. No need to take off the lower rocker box or the heads below it.
Pull the pushrod tubes off and use the spring part of some paper binder clips to hold up the lifters for cam removal.
quigley
Exhaust System Topics
16
Sep 26, 2022 02:09 AM
Gordito
Aug 24, 2020 11:29 AM
8828alex
Jan 29, 2013 07:20 AM
rattlebones
14
Jun 23, 2010 09:36 PM
bruggy
106
Mar 20, 2008 07:58 AM
