cold compression test
Old Oct 27, 2014 | 03:30 PM
iamron6113's Avatar
iamron6113
Default cold compression test
Can someone please tell me how to turn engine while by-passing ignition ?
Thanks,
Ron
Old Oct 27, 2014 | 04:02 PM
roadking2014's Avatar
roadking2014
you mean like turning the back tire while the bikes on a lift and the bike in a higher gear?
Old Oct 27, 2014 | 04:05 PM
SBates08's Avatar
SBates08
Why would you need to bypass the ignition?
2010 Limited with some stuff
Old Oct 27, 2014 | 04:06 PM
dyna rider's Avatar
dyna rider
Default Compression Test
Why not just pull the plug wires off the plugs and hit the starter...You will have to mount a compression gauge in one of the spark plug holes anyway if you are going to test for compression.
Old Oct 27, 2014 | 04:48 PM
mkguitar's Avatar
mkguitar
Originally Posted by dyna rider
why not just pull the plug wires off the plugs and hit the starter...
Because the ignition system will blow !
You can do that with points, you can try that with an electronic ignition- and you may get away with it or not.
you can run the motor if the plugs ( removed), are grounded to the motor, so that the circuit is complete- that way the field in the coils may collapse completely
OP, compression checks need be done when the motor is at operating temperature so that all the parts have expanded- this will give better or accurate numbers.
Mike
Old Oct 27, 2014 | 08:03 PM
iamron6113's Avatar
iamron6113
Mike
I figured out what I needed to jump start and bypass electronic ignition (for reason mkguitar said).
Connect solenoid terminal and positive battery connection at starter.
For anyone wanting to know
a cold compression test is performed (I learned this from a very good Harley mechanic.)
1) remove air cleaner;
2) open throttle full;
3) remove plugs and insert compression testor into either cylinder;
4) make a connection between the solenoid terminal and the positive battery cable connection post at starter. (I use remote starter. If not, can cross these connections using electrician type INSULATED wire.
Engine will rotate and let it rotate a few 2-3, 3- 4 times - whatever, until compression tester dial stops jumping/moving up and holds a steady measurement. Then, do same on other cylinder.
Reading for a TC88 should be b/n 150-180 lbs (I think that’s it for TC96 and all Harleys but really, I’m not sure - maybe someone else knows). Anyway, the readings should be between 150lbs to 180 lbs w/ each cylinder reading w/in 10 lbs of the other = good.
Old Oct 27, 2014 | 08:05 PM
2-Piece's Avatar
2-Piece
Unplug the connection to the coils or ground the spark plug wires/cables.
dakota772
Electrical/Lighting/Alarm
Dec 15, 2017 08:03 PM
Bobv71
Mar 24, 2016 08:10 PM
francisstark1
Jun 11, 2012 11:14 PM
JamesP
Mar 23, 2009 06:10 PM
hddave2
Mar 27, 2008 10:39 AM
