Let's talk about cutting down a stock windshield
Old Nov 9, 2014 | 11:54 AM
cncmike's Avatar
cncmike
Lexan shields resist cracks. Never try to cut an acrylic shield at home. The perfect blade for a saw produces dust larger than a grain of salt. If it's melting the blade is too fine. If its vibrating a lot the blade is too coarse. Try about 18 teeth per inch.
Old Nov 9, 2014 | 12:09 PM
SeaZund's Avatar
SeaZund
I used a rotary air cutoff tool when I did my last one; it avoids the vibration issue a jigsaw will have
Old Nov 9, 2014 | 12:25 PM
swervin irv's Avatar
swervin irv
Cut a 1/16 to 1/8 inch above your marked line and sand down to the line.........
Old Nov 9, 2014 | 03:28 PM
steelerdude1's Avatar
steelerdude1
Originally Posted by ONEDOWNAND5UP
Tape it up, ALL up in and out then find someone with a bandsaw. Sand the edge a little a quick wipe with a rag damp with acetone and you are done.
Mark
Acetone, is that nail polish remover? What does it do, melt and finish the edge?
I got the shield cut down and sanded. There is a spot on the one rounded edged that did not sand to a shine (1200 grit final sand) hoping that acetone will do the trick, but waiting on replies.
Anyway here is the finished product. I used a pneumatic die grinder with a cut off disc. Not to bad for a winter shield, and best of all the shield was a freebie.
Old Nov 9, 2014 | 03:59 PM
SeaZund's Avatar
SeaZund
looks much better
Old Nov 9, 2014 | 06:56 PM
steelerdude1
I didn't wait for a response on the acetone, and just did it, and it was a mistake. It work nicely on the top flat part where it was already sanded very smooth, but the areas on the corners that I was trying to address got pretty messed up. It put tiny little cracks, only about 1/16" long, along these edges. I ended up having to sand all of it out. This time I broke out my jitterbug sander. It's all good now, but caused me some extra work.
Old Nov 9, 2014 | 07:18 PM
Northbound Southerner's Avatar
Th acetone didn't crack the shield. They must have already been there. Acetone eats plastic so be careful where you let it drip. Bike looks good!
Old Nov 9, 2014 | 08:23 PM
OwnerOfHarriet's Avatar
OwnerOfHarriet
Lots of good advice --
my steps are
1) find the height you need and mark it
2) I put down blue painters tape on both sides and then put duct tape over that
3) I use a very fine metal cutting blade in a jig saw
4) this step can be done one of 2 ways. A. if the windshield is off, I use a disk sander to smooth out the edge. B if it is still on the bike, I use sandpaper wrapped around a block to sand out the irregularities -- used up to 220 or 320 grit
5) I take a ligher and just slightly melt the edge for a finished look.
Old Nov 9, 2014 | 08:55 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
I would have used a Roto-Zip tool to trim it. Basically it's a small hand held router that operates at extremely high speed. Works great on lexan or plastic.
Old Nov 9, 2014 | 10:00 PM
user 8373900's Avatar
user 8373900
As was stated, the acetone didn't crack the shield, I have cut a 1/2 dozen and never had an issue. Sorry I'm late to the party I was at my grandsons 2nd birthday.
Mark
