There are numerous places on the net and youtube that can show you how to do this. I've done it myself and the results were great...as long as you make a good cardboard template, tape the entire shield to prevent scratches, use a very fine tooth jig saw blade and go very very slow. Keep the cut cool. And sand or polish the cut edge.
I have to echo what the poster above said. I have made a couple of windscreens from scratch and had excellent results cutting both of them. I covered my work bench with carpet to keep from scratching the plastic. I made a good template out of poster board and taped it to the sheet of Lexan. Next I outlined the template with a fine pointed laundry marker (black) so I could easily see the cut line.
It is very important to use a small toothed blade in your sabre saw. When I finished the cutting I used 600 grit wet/dry sandpaper to finish up the edges. It really looked like a store bought windscreen both times.
I purchased the Lexan in a pretty good sized sheet from Lowes, back in the glass department for about $30.00. It took about an hour to cut the new shield once the prep work was done. If you are a patient person, this is easily attainable.
^^^ What he said^^^^ My stock shield was getting old, Instead of buying something that may not be the right one. I did the same thing, Lexan made my own. Taped it off, jigsaw with a semi coarse blade, not to overheat. sanded it and it worked out perfect.
