2013 flhtcpi engine oil capacity
Old Nov 11, 2014 | 07:58 PM
claytonandson's Avatar
claytonandson
6th Gear
Question 2013 flhtcpi engine oil capacity
ok, to sound a little dumb....getting ready to hit 1K on my ride....front of manual says 4 quart capacity engine, oil change section says 3 quarts. which is it ?
Old Nov 11, 2014 | 08:10 PM
Northbound Southerner's Avatar
Both...4 quarts dry and about 3 quarts on a change...Change it, put in 3, warm it up and then check it. Add as needed...
Old Nov 11, 2014 | 08:11 PM
harleycharlie1992's Avatar
harleycharlie1992
Unofficial HDF Chaplain
don't fill to the top though, I usually put 3 1/2 total with a filter, and that is a short 1/2 qt!
Old Sep 9, 2024 | 12:30 PM
SGSGUY's Avatar
SGSGUY
harleycharlie1992, I'm with you on that and even a bit less oil for my model and year. I had issues with excess oil blowing out head breather tubes into air cleaner quite a bit and onto my jeans at highway speeds, on my 2022 SGS. I read all the issues, started looking into vented crankcase breathers, head breather tubes directed down to under bike into a canister or just blow into the environment etc. etc. My master mechanic told me to fill the engine oil to midway between full and empty on dip stick - problem solved that easy. Not to open cans and cans of worms, but that worked for me and it was free. He also told me once a ride when bike is at operating temp give it one redline shift to burn off everything on piston heads.
Old Sep 9, 2024 | 01:26 PM
Keithhu's Avatar
Keithhu
10 year old thread FYI.
Old Sep 9, 2024 | 03:02 PM
SGSGUY's Avatar
SGSGUY
Holly S**t, I didn't even look at the date ROFL. Well it shows you it's a decade old thing that keeps coming up.
rickpaul
Jul 29, 2018 11:03 AM
robertski463
Oct 17, 2016 07:45 PM
Bigg Lou
Sep 11, 2013 09:03 PM
MDodson
EVO
22
Jul 29, 2012 06:05 PM
alyaseen
Jul 20, 2011 10:59 AM
