Stereo is dead
Old Nov 12, 2014 | 09:43 PM
Matlock's Avatar
Matlock
Stage III
Default Stereo is dead
I have an 04 Road Glide with the stock stereo. Rode 2 weeks ago and when I parked it the stereo worked fine. Went to ride today and the stereo will not come on. Not even the clock. All fuses are good. I am getting 12.5 volts to the stereo plug on both battery pins and the signal pin also. I am getting a good ground also. I am thinking something is wrong internally with the stereo. Any ideas?
Old Nov 12, 2014 | 11:03 PM
BQsHX's Avatar
BQsHX
Check out www.ironcrossaudio.com
They specialize in the Harmon Kardon radios.
Old Nov 13, 2014 | 04:51 AM
Matlock's Avatar
Matlock
Stage III
Thanks. I'll give that a try.
Old Nov 13, 2014 | 05:53 AM
lizard86's Avatar
lizard86
Yup. Either check out ironcross or go to biketronics and get an aftermarket head unit. Mine did the same thing on my 06 and I replaced it with a Sony from biketronics.
Old Nov 13, 2014 | 07:08 AM
hdfat2001's Avatar
hdfat2001
The Radio is your '04 is not Harmon Kardon, it was made by Radio Sound. They do offer a flat rate repair for $250.00. http://www.radiosound.com/customer_service.php
Old Nov 13, 2014 | 10:39 AM
biker_ded's Avatar
biker_ded
Mice? It's that time of year. Just sayin'.
Old Nov 13, 2014 | 11:06 AM
austinslider's Avatar
austinslider
Maybe a good time to upgrade the stereo and put in an aftermarket HU and speakers...
Old Nov 13, 2014 | 12:13 PM
SeaZund's Avatar
SeaZund
just a side note, if you replace it with a non-Harley radio, you'll lose your intercom and CB functions. Have you tried re-seating the harness on the back of the radio; perhaps using some contact cleaner? Could be something as simple as tarnish on the contacts.
Old Nov 13, 2014 | 12:45 PM
DanDman's Avatar
DanDman
I had a similar problem. It was my ground screw on the steering neck, it was loose. The front brake line clamp shares the same screw.
Also check/wiggle all the connections as SeaZund noted.
Old Nov 13, 2014 | 03:19 PM
Bill03E's Avatar
Bill03E
Radio sound is the way to go IMO, so called upgraded aftermarket units just don't last, a friend has a road king with a faring , and he has had to put in a new unit every year he has had it , until we put a factory HD radio in the faring, rain, snow, and riding hasn't hurt it, and it has been 3 years in the faring.
He even had the cover on the after market ones, they still died.
