Idle Problem with New SG
Old Apr 14, 2007 | 12:53 AM
Rick 547's Avatar
Rick 547
Default Idle Problem with New SG
Just brought my new SG home this afternoon and noticed that once it warmed up that it idled rough. As I was coasting up to a stop sign I thought I had a flat tire because of the vibration I had. When I accelerated away from the stop sign every thing seamed to be ok. Then the same thing happend at the next stop. Does anyone know what this might be? It seams that it idles rough once you disengage the clutch.
Old Apr 14, 2007 | 01:12 AM
sprint12's Avatar
sprint12
Default RE: Idle Problem with New SG
Probably because the A/F ratio is to lean and it can not breath because of the restricted stock exhaust. IMHO.
Old Apr 14, 2007 | 03:17 AM
Dago_RoadKing's Avatar
Dago_RoadKing
ORIGINAL: Rick 547
Not to be funny but. Are you sure it's not just the movement of the engine in the frame on the rubber mounts that you are feeling? I say this because I just moved from a bike with a 103"B motor to a 96" Street Glide, and I remember thinking something was wrong when I pulled to my first stop light. Then I thought back to my Road King and realised it was just the rubber mounted motor doing it's thing. If this is your first HD bagger don't be suprised if you hear the motor tap the frame every now and then. I know the first time it happened to me the motor lightly taped the frame.I thought someone was throwing things at me... problem is there was no one around.
Old Apr 14, 2007 | 03:54 AM
TOMCENTRAL's Avatar
TOMCENTRAL
Mine did the same thing.Ran fine till warm,then rough.The front O2 sensor stopped working when it got warm.Regards,Tom
Old Apr 14, 2007 | 08:56 AM
iclick's Avatar
iclick
ORIGINAL: Rick 547
The '07 engine in stock form idles quite rough, IMO. When I test-rode a RK last August I was taken aback by how much it shook at idle. Now that I've bought an '07, I've gotten used to it, but after getting the A/F right with slip-ons and an A/C, it is a bit smoother--or maybe I'm just more accustomed to it after five months. It still shakes, but doesn't sound like my old Evo that had a potato-potato idle like a Harley should. These new bikes just don't sound right at idle.
Old Apr 14, 2007 | 10:50 AM
Rick 547's Avatar
Rick 547
This is not the first rubber mouted engine I have had. In fact that is all I have owned since 1997 and I have gone trough a 1997 Dyna, 2001 Dyna WG, and a 2994 Road King Custom and have never experienced this problem before. As to it being not able to breath my SG has had a Stage On Air Cleaner, SE Exhaust and Downloadinstalled beforedelivery.
I'll take it back to the dealer on Monday once the weather clears up and see what they say.
Old Aug 20, 2007 | 04:07 PM
mooreto's Avatar
mooreto
4th Gear
My 07 RG is having rough idle issues. When pulling up to a stop the idle would dive down to 900 then up to 1100 and then bounce around. The bike has even just died a couple of times but then start right back up. The dealer tells me a remap is available to correct that. I'm going in this week.
Old Aug 21, 2007 | 03:13 PM
07SG's Avatar
07SG
Mine did this often when it was new.
It hardly ever happens now that I have some miles (5,000), and it is bone stock.
stevequad
EVO
30
Nov 24, 2014 03:30 PM
ehc0720
Aug 6, 2012 02:11 PM
k3rodgers@sbcglobal.net
Jul 21, 2009 10:58 AM
cravenc
Aug 22, 2007 02:46 PM
aj373ku
May 5, 2007 07:08 PM
