200mm tire on 08 street glide DONE!
Old Nov 16, 2014 | 01:22 PM
harleyizlife's Avatar
harleyizlife
4th Gear
Default 200mm tire on 08 street glide DONE!
So I had a itch I had to scratch. I had a 140 16 inch tire on my 08 street glide. dealer told me there was no way to fit a 200mm 18 inch tire on the rear.so I had to do it ,right? yep,no welding, no cutting, done! and it looks really fat. the belt drive belt has 1/16 inch clearance on each side, man it is close but it works fine.
Attached Thumbnails 200mm tire on 08 street glide DONE!-photo-2-.jpg   200mm tire on 08 street glide DONE!-photo-3-.jpg
Old Nov 16, 2014 | 01:36 PM
Northbound Southerner's Avatar
Did you put that on the 140 rim?
Old Nov 16, 2014 | 01:48 PM
harleyizlife
4th Gear
No had to get a 5.5 inch wide x 18 rim and change the swingarm . direct bolt in arm, I used a fat baggers rear fender.
Old Nov 16, 2014 | 01:49 PM
OK. I was a bit worried for a minute. I have seen that conversion and you are right. It is close to the belt. I have a buddy that has a ton of miles on his though and he has never had an issue...
Old Nov 16, 2014 | 02:14 PM
gartec81's Avatar
gartec81
That looks great, Could this be done to a 04?
Old Nov 16, 2014 | 02:49 PM
harleyizlife
4th Gear
yes it can be done. contact john at 701 837 1467 specialty HD. he helped me with the parts I needed. wheel,swingarm,fender,etc .
Old Nov 16, 2014 | 06:48 PM
The Q's Avatar
The Q
That's some serious coin for the kit!!! Then add the rim and tire in. I've been following all the threads for a 180 conversion. I'm close to doing it, just have to convince myself to buy a new rim. Fat Baggers makes a nice inexpensive 180 kit for the '07 and '08 bikes, I just don't care for their fender. Now that I've found a good custom body shop, I might just finally pull the trigger on a 180 conversion.
None the less, your 200mm looks awesome!!!
Old Nov 18, 2014 | 02:36 PM
harleyizlife
4th Gear
Well look at it like I did, your not going to live forever. pull the trigger and enjoy it. something no one told me with the fbi cats eye tail light that I think is really cool looking is that the cats eye light itself has amber color directionals intergraded in the light itself,it also has the safety flashing led brake light.it flashes like 4 or 5 times then goes steady red. not to mention it has the license plate light in it also.
Old Nov 18, 2014 | 05:16 PM
Gliden's Avatar
Gliden
Looks great. Belt part is a bit scary though lol
Old Nov 20, 2014 | 08:09 PM
harleyizlife
4th Gear
fender painted and mounted now looks way better than stock!!!!!
