Alright, I've seen several posts about using a penny and a quarter to check the tread depth for the 2/32's safe depth.
Which is it. Penny? Or quarter?
In this case size matters!!
this is my two reasons to use a quarter and a penny.
quarter 4/32s tread is good. This is my winter (snow and wet) limit on tread depth.
Penny 2/32s. its time to replace the tire. Can get by in warm, dry weather till tires are available.
Place a penny into several tread grooves across the tire. If part of Lincoln's head is always covered by the tread, you have more than 2/32" of tread depth remaining.
Place a quarter into several tread grooves across the tire. If part of Washington's head is always covered by the tread, you have more than 4/32" of tread depth remaining.
Place a penny into several tread grooves across the tire. If the top of the Lincoln Memorial is always covered by the tread, you have more than 6/32" of tread depth remaining.
I knew I shouldn't have trusted the dealer. They told me to check it with a hundred dollar bill. I hand it to the mechanic, and when I pick up the bike they tell me the tread depth.
