Tire checks
Old Nov 16, 2014 | 02:19 PM
Brucecmc's Avatar
Brucecmc
Default Tire checks
Alright, I've seen several posts about using a penny and a quarter to check the tread depth for the 2/32's safe depth.
Which is it. Penny? Or quarter?
In this case size matters!!
Old Nov 16, 2014 | 02:53 PM
btsom's Avatar
btsom
The folks who show this check on TV use the penny. As far as I know the legal limit on MC tires is 1/32 so the penny leaves some wear unused if going down to 1/32 doesn't bother you. I have seen no tires in the last 20+ years that didn't have the wear bar indicators molded into the tread. They are little ridges higher than the base of the tread groove and when the tread wears down to the point that the wear bar is even with the tread the tire should be replaced. If you look for the wear bars you don't need to scrounge up a penny.
Old Nov 16, 2014 | 04:42 PM
Moe55's Avatar
Moe55
Look on the side of the tire just below the tread you will see a small triangle that is pointing to the wear bar on the tire.
Old Nov 16, 2014 | 04:52 PM
Brucecmc's Avatar
Brucecmc
Understood. And I'm familiar with the wear bar. I was just curious if anybody knew which was the more accurate (or correct). Penny or quarter.
Thanks
Old Nov 16, 2014 | 06:13 PM
themensh's Avatar
themensh
Thanks
Always was told if you insert Lincolns head into the tread...if his head shows, time for a new tire. But a tire tread depth gage is cheap... and would fill up a spot on your tool wall!
LOL But I go by the tread indicators on the tire it self.
Chuck
Old Nov 18, 2014 | 03:51 AM
NoCoLoco's Avatar
NoCoLoco
Save your loose change for the gumball machines and go by the wear indicator on the tire. If it is recessed you're good to go, if it is flush then it's time for a new tire. It doesn't get any more simple than that!
Old Nov 18, 2014 | 05:26 AM
binkman78's Avatar
binkman78
Answer to the question is: Penny
Old Nov 18, 2014 | 07:50 AM
EasTexUltra12's Avatar
EasTexUltra12
This whole thread made me smile. We spend $20K+ on a bike and want to know if it's a penny or a quarter to check tread depth?? LOL Tread depth gauges are 3-5 bux at any auto parts store.
David
Old Nov 18, 2014 | 08:10 AM
grbrown's Avatar
grbrown
In my experience over the last 40 years we don't need either! When a tyre gets low on tread depth it tends to change how it rides, which is a tell-tale sign that a change is nigh.
Old Nov 18, 2014 | 08:27 AM
hdbob2006's Avatar
hdbob2006
Go to any auto parts store and invest $4.00 on a tread depth gauge. How do you check your tire pressure?-Thump 'em with a hammer?
