Odd starting
Old Nov 17, 2014 | 02:32 PM
EasTexUltra12's Avatar
EasTexUltra12
Originally Posted by jmn1960
the stealer wants $195 for the batt 1yr warranty , i went to batteries plus $155 with tax 2yr warrenty
Searching Batteries + only shows one battery. $99.99, 385CCA.
Do you have a part# for the $155 item?
David
Old Nov 17, 2014 | 02:40 PM
jmn1960's Avatar
jmn1960
Originally Posted by EasTexUltra12
Do you have a part# for the batteries plus item?
David
30la duracell ultra $144.95 plus tax=$155.09
Old Nov 17, 2014 | 02:50 PM
EasTexUltra12
Thanks!
Old Nov 17, 2014 | 02:54 PM
jmn1960's Avatar
jmn1960
welcome
Old Nov 17, 2014 | 02:55 PM
jmn1960's Avatar
jmn1960
it is a 400cca battery also
Old Nov 17, 2014 | 03:52 PM
skratch's Avatar
skratch
Originally Posted by DHubbs
I believe it states in the manual to wait until the check engine light goes out before cranking engine. This is usually a second or two after the fuel pump switch's off.
no, this is not correct. the manual tells you that the cel will illuminate for app. 4 seconds, but it does not state that you have to wait for the light to go out.
$155 is too high for that battery. you can find the proper battery somewhere else for right aroudn $100
Old Nov 17, 2014 | 03:55 PM
wscott's Avatar
wscott
Bike has started to act a little funny on startup. This happens when starting a cold engine. Turn the ignition on, wait for fuel pump to pressure up, pull clutch in, press the button. Bike will turn over once, stop for a beat, then spin up and start. It's never not started. I keep it on a Battery Tender religiously, charging system is charging fine. I have not taken the battery out and had it load tested. It's a 2012, so that battery is 3-4 years old.
Thanks
David
Yup,the above $100 est for a good quality battery saving $50 is right on the money.
Below i pasted links to quality factory activated hi perf AGM batteries at good prices vs locally at the stealer or automotive store where same type hi perf agm batteries of equaly cca & quality cost approx $30-$50 more.
1st battery is high output @ 600cca ($128) and other 2 are 400cca ($99.95 & $108) which l believe is still a bit more cca then stock original battery had that came with the bike when new.
All 3 batteries have free shipping too!
My 09 glide has the $99.95/400cca hi perf AGM version battery which spins it over well,i believe both of the 400cca batteries
are mfg by Deka which mfg's great hi quality long lasting factory activated AGM Powersort batteries.
I have used the Deka type AGM battery mult bikes including 3 of mine along with other peoples bikes i maintain too with great result every time,they seem to last 5-6 yrs on avg ,but i have seen a few go 6.5-7yrs too.
The 600cca battery peaks my interest for sure , it would be great battery for modded bikes with a larger displacement motor & higher compression.
Scott
http://powersportbatteries.com/more-...nk-etx30l.html
http://www.ebay.com/itm/221587816249...MakeTrack=true
Amazon.com: ThrottleX Batteries - HDX30L - Harley Davidson Replacement Motorcycle Battery. Same Day Shipping When Ordered M-F By 3 PM EST!: Automotive Amazon.com: ThrottleX Batteries - HDX30L - Harley Davidson Replacement Motorcycle Battery. Same Day Shipping When Ordered M-F By 3 PM EST!: Automotive
Old Nov 17, 2014 | 03:57 PM
jmn1960's Avatar
jmn1960
not with a two year free replacement warranty , and it is a perfect fit for my 2005 uc
Old Nov 17, 2014 | 04:34 PM
wscott's Avatar
wscott
IMHO its not worth the additional 50%/$50 in cost for the 2 yr warranty.
That's because there are other good quality hi perf high output batteries avail these days (see links i posted in my prior post to this thread) that go the distance thus not needing a 2 yr free replacement warranty .
I have been wrenching bikes and cars for other people for 4+ decades and can honestly say with the many new batteries i have installed over 4 decades i have had 1 new battery that i can remember that had gone bad .
That may be because i always installed good quality batteries with higher cca's to begin with thus being less likely to crap out early.
Can a new bike battery can go bad shortly after install or 1-2 yrs down the road too,yes.
But that doesn't happen often enough to be so concerned to spend 50% more just for a better warranty.
The time i'd worry about warranty on a bike battery would be if i was going to buy for example a very pricey Lith-Ion bike battery because in higher drain & high heat apps Lith-ion batteries have had issues at times with melting down or starting on fire.
And the battery in an electraglide ultra classic gets over baked with heat from the motor and at times can have a lot of load on it too
depending on how many additional electronic items are installed on the bike vs its charging systems output where the balance between max drain & charging system output isnt optimal or not good.
Just my $.02.
Scott
Old Nov 17, 2014 | 05:40 PM
EasTexUltra12
Originally Posted by wscott
CCA schooling please.
OEM is 385, and other than going south too soon, it did a good job. 400CCA batteries are pretty easy to find and for little or nothing more than the 385's. Powersports has a 600CCA monster for $28 more. For better or worse, I'm in the "bigger is better" club. I'm leaning towards the 600CCA battery. What would be the pros and cons of this 1/3 larger capacity battery?
Thanks,
David
