Bad Compensator
Old Nov 19, 2014 | 01:20 PM
razorsedge's Avatar
razorsedge
Actually you can gain some good insight by just looking at the assembly. Primary oil that has a red hue from the metal fretting and also look closely at the ramps on the assembly, worn compensators will show pitting on the ramps and will be very shinny. The new revised (for the 3rd time) compensators have better oiling methods. The main reason they fail is lack of lubrication.
Look at the pics I have attached. Some pics show the new revised compensator. I will also try to upload a video showing me taking apart a noisy compensator. It was pulled apart when the owner started forst noticing a noise coming from the primary
Attached Thumbnails Bad Compensator-imag0248.jpg   Bad Compensator-imag0274.jpg   Bad Compensator-imag0323.jpg   Bad Compensator-imag0333.jpg   Bad Compensator-imag0343.jpg
Old Nov 19, 2014 | 02:54 PM
danzio's Avatar
danzio
Does the Stator need to be replaced if upgrading to the "new revised" comp? I just put a new Stator in a couple of months ago due to the leaking stator plug wire issue. I didn't have a compensator problem at the time but I think I am now beginning to show some symptoms.
Old Nov 19, 2014 | 03:04 PM
Weavr99FLHT's Avatar
Weavr99FLHT
You need to replace the rotor on '10 and earlier I believe. Compensator kit 40100061 includes rotor assembly 30041-08. Compensator kit 42200064a does not.
Old Nov 19, 2014 | 03:40 PM
kitehog's Avatar
kitehog
Originally Posted by Notgrownup
My 07 did all of this, starter was replaced with a high torque and the problem stayed , it all went away with a SE comp....I had no primary noises only a sound like a car starter that is shimmed wrong, every one told me it was a starter problem but since I ot a new comp about 15000 miles ago it's gone
Exact same experience with my 08 Electra glide
actually put two All ***** Starters in before I gave up and did the compensator. No issues since I did that with over 10K miles.
Old Nov 19, 2014 | 03:51 PM
scottman50's Avatar
scottman50
Hey guys. Sorry if this is a stupid question. I have just bought a 2014 Limited CVO.
Will the 110 engine have the se comp?
Thanks,
S.
Old Nov 19, 2014 | 09:18 PM
Notgrownup's Avatar
Notgrownup
Thanks,
S.
Yes, it has the latest.
Old Nov 21, 2014 | 04:38 AM
95ci springer's Avatar
95ci springer
Ok. Thanks everyone. I'll try to convince him that he needs to replace his comp.
Old Nov 21, 2014 | 08:47 AM
texaswiz's Avatar
texaswiz
Pretty much all of the compensators have been questionable for the last decade. The Harley compensator is poorly designed.
That is why they keep bringing out "new and improved" versions. I am not at all sure they have got it fixed with the 2015 models. It looks different, but time will tell.
Old Nov 21, 2014 | 11:14 AM
Notgrownup's Avatar
Notgrownup
I guess the higher lubrication baffle would help make its life a little longer...
Old Nov 21, 2014 | 09:48 PM
texaswiz's Avatar
texaswiz
Originally Posted by 95ci springer
Can you guys tell me what years and models came with bad compensators? My dad has an 08 Electraglide Classic and has issues with the starter. Sometimes when he starts it when the motor is hot it sounds like the starter grinds the teeth and sounds horrible. I'm wondering if it's related to the compensator.
Sounds like he is getting "kickback" which happens when the engine stops on a compression stroke and you try to start it when it is hot, mainly in summer months.
A compression release or EZ start cams are what is really needed. Most of the newer bikes come from the factory with compression releases built into the heads now. 2008, 2009 and 2010, not so much.
