Many mix stock oil 50/50 with the se. I'd recommend a fork oil gauge so each tube has the same volume,
put progressive HD springs in front with 1.25" spacer used screamin eagle HD fork oil which is 15w front end too much SAG.
trying 1/2" more on spacer and going to 20w fork oil
2009 road king Ohlins 357HD on rear trying to match suspension
i'm 6'4 255lbs bike is just tad under 900lbs
trying 1.75" spacer with 20w oil. screw screamin eagle they don't want to post the oil weight on lable, just saying it's heavy duty, actually found it to be 15w
THANKS FOR THE SHOCKS HOWARD AND THE ADVISE, EVERYTHING IS FALLING INTO PLACE. MOTORCYCLEMETAL.COM
