Bars not straight?
Old Dec 7, 2014 | 07:39 PM
Sean G's Avatar
Sean G
6th Gear
I thought maybe I sit off centre on the bike, but since you guys all notice the same issue I don't feel so lop sided! Thanks for the ideas and I look forward to hearing any other comments. I'm a new forum user and have seen some great ideas already.
Old Dec 8, 2014 | 06:15 AM
smokindave's Avatar
smokindave
Something else to consider. The cams on the rear wheel adjustment only need to be out a little bit on one side over the other and you will get this same feeling thru the bars.
You will sense the bars feeling out of adjustment or a slight pull to one side, it only takes a little. Make sure each side has the cams tight up against the stops.
Old Dec 8, 2014 | 10:00 AM
Guitarman_sg's Avatar
Guitarman_sg
I had the same issue with my bike. When I changed to my T-bars they were crooked, I figured it was the bars. After loosening them up slightly, I had my son hold them in place an re-tightened them. I figured it was the rubber bushings. I probably should have replaced them but I have not had a problem with them since.
Old Dec 10, 2014 | 08:52 AM
bobx67's Avatar
bobx67
i had that on my rk. it was the handlebar clamps that werent straight in the top triple clamp. i loosened them up, straightened them out and tightened them back up. problem solved. i thought the bars were tweeked or someone hit it or something but it was an easy fix.
Tarkus60
Nov 12, 2016 09:58 PM
Kayakguy
May 21, 2015 10:08 PM
Tek74
Feb 21, 2012 04:57 PM
rrambo
Apr 27, 2011 09:32 AM
Bulldawg
Oct 24, 2007 07:42 PM
