Greetings All, I bought a USB cord to connect to my accessory plug under my seat on my SG. I connected the deutsch plug and ran the wire in the conduit tray under the gas tank. I mounted the USB end in the left side on my switch housing. The issue I have is the plug is hot when the ignition is on and the Acc switch does not operate the plug. Has anyone else installed one of these had this issue?
Thanks for the help! I need to figure out how to pull the connector apart and move the pin! I never did a deutsch connector. I have tools for the molex pins, They are no help for this connector
