would not start this morning
Old Dec 8, 2014 | 06:07 PM
mkguitar's Avatar
mkguitar
I don't have a manual for your 2005.
many of the rubbermount models have a woven steel groundstrap bolted to the inner primary case and to the frame- up underneath
if that strap is gone...the clutch cable sometimes becomes the new ground and it may smoke.
mike
Old Dec 8, 2014 | 10:44 PM
jmn1960's Avatar
jmn1960
wtf get home fires right up,turn off pull seat check voltage 12.9,check starter bolts tight loosen and retighten,check all connections clean and tight, fire up charging 13.9, rev to 2000 charging 14.3, mabe it just wanted to take the day off , but still puzzled,
Old Dec 9, 2014 | 01:24 AM
ke5rbd's Avatar
ke5rbd
If it does it again look at the headlights and if they go out or dim it is a bad connection somewhere. If you hear the click as you said it is likely the solenoid not making good connection from the positive connection on the solenoid to the starter positive connection inside the solenoid. The lights won't go out from this. The solenoid is very similar to the way the older Chevy's were and they were very bad about this.
Old Dec 9, 2014 | 06:28 AM
Jackie Paper's Avatar
Jackie Paper
Originally Posted by jmn1960
still puzzled,
How many miles on starter? Are you a hold the starter in till it starts or a teaser type who hits it and lets off 2 or three times? I am a one hit starter..at 45K, mine is still fine and about 3/4 of that is a lot of starts in the city local. I have see when amp fall off which will drop the voltage will lower the power of the solenoid magnet and the starter will either kick out or the motor will kick back with a bang when it throws the gear out or bangs the compensator (not sure witch bangs).
Old Dec 9, 2014 | 08:01 AM
tpcowfish's Avatar
tpcowfish
mike
I had a 97 do this, started acting like yours, grounded thru the clutch , is clutch working properly ?, mine welded the clutch cable, making it hard to operate, was ground
Old Dec 9, 2014 | 08:42 AM
jmn1960's Avatar
jmn1960
I hold the button till it starts , not two or three trys
clutch seems free and working properly
mabe just a glitch
Old Dec 9, 2014 | 08:48 AM
leon anthony's Avatar
leon anthony
MKGUITAR you 06 manual is the same for the 05 except for the radio
Old Dec 9, 2014 | 09:17 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Perfectly normal for worn solenoid plunger contacts.
You will likely not have it happen for a while. But gradually, it will get more and more frequent.
You can dress the contacts, but replacing them tends to work better.
Old Dec 9, 2014 | 09:21 AM
jmn1960's Avatar
jmn1960
can the soleniod be pulled without pulling the starter as the 05 model needs the primary removed. I take it you are talking about the contacts in the soleniod
Old Dec 9, 2014 | 10:23 AM
foxtrapper's Avatar
foxtrapper
Yes I'm talking about the contacts in the solenoid. Looks like a Nipondenso starter to me, so you should be able to do the job right there in the bike.
And, after looking around, I see Harley sells a kit for this. Probably cheaper as a generic Toyota starter kit. But, at least with a Harley kit you'd know the parts would fit.
http://www.harley-davidson.com/en_US...ts/-J03700.pdf
