engine ground strap
Old Dec 9, 2014 | 06:05 PM
jmn1960's Avatar
jmn1960
Default engine ground strap
2005 ultra ,, some one sugested to check the ground strap from the inner primary to the frame on my bike ,, i cant find it in the manual or one on the bike , does the 2005 have one and mine is just missing ? or is this on lator or earlier models.
thanks mike
Old Dec 9, 2014 | 06:38 PM
Duracell's Avatar
Duracell
What issue are you trying to trouble shoot? I doubt any year bike had a ground strap on the primary housing
Old Dec 9, 2014 | 07:07 PM
jmn1960's Avatar
jmn1960
chaseing starting problem, check all mounting bolts for tightness ,batt checked good for load test,all connections good , clean and tight , someone sugested to check the ground strap from i/p to frame but i cant find one on my bike or in my manual so i just put a feeler out to see if someone knew if the bike orignaly came with one.
thanks
Old Dec 9, 2014 | 07:08 PM
MIKE93SVT's Avatar
MIKE93SVT
It's under the trans, back side of the primary. Every rubber mount bike has one. If your starter solenoid just clicks, that's a good thing to check.
Mike
Old Dec 9, 2014 | 07:13 PM
jmn1960's Avatar
jmn1960
Mike
ok thanks i'll look again,, probaly overlooked it ,, but when i resealed the primary and had it off to do the shift shaft seal i dont recall taking one loose,, can you see it from the bottom , or from the side??
thanks
Old Dec 9, 2014 | 07:34 PM
MIKE93SVT's Avatar
MIKE93SVT
From the bottom. Use a flashlight. It's bolts to the crossmember right under the trans and is only about 4-5" long. Goes right to the backside of the primary under the input shaft area
Mike
Old Dec 10, 2014 | 02:28 PM
Duracell's Avatar
Duracell
Mike
Guess it depends on the year. I've never seen one on a primary housing. On my 08 the negative battery cable terminates on a bolt on the top backside of the transmission not the primary.
Old Dec 10, 2014 | 02:32 PM
jmn1960's Avatar
jmn1960
yup mine goes to the rear starter mounting bolt ,, got under there last night and mine does not have one to the primary off of the crossmember either
Yankee Dog
Jun 1, 2019 02:13 PM
Daedalus
May 20, 2018 02:14 AM
cajun1957a
Shovelhead
108
Feb 23, 2014 01:01 PM
Mountainkowboy
EVO
Feb 7, 2012 03:16 PM
funkadellic69
Mar 21, 2011 03:55 PM
