anti seize
Old Dec 11, 2014 | 07:58 AM
dirtracin23's Avatar
dirtracin23
Rinehart used to specify the use of high temp (copper) silicone with the installation of his pipes. Although this last set I just put on didn't have a mention of it anywhere.
Old Dec 11, 2014 | 12:52 PM
UltraNutZ's Avatar
UltraNutZ
probably stopped recommending it's use because people were destroying their tips trying to get them off with that crap on them. That stuff has it's purpose but it really sucks later on after you've put a few miles on it. It's like a sealant/glue. I would never use it on on my exhaust. Find something else if you need a sealer. As to whether or not it's needed, I've never put an exhaust on that needed any type of sealer. If it does, that tells me something else is wrong.
Old Dec 11, 2014 | 01:11 PM
Pumba11's Avatar
Pumba11
I will have to disagree with you NutZ. I don't use it as a sealer but to aid in removal, and for them not to rust together. I change my mufflers a couple times a year depending if I am touring or not. Anti sieze helps them to not rust together. The times I forgot to use it I had a much harder time with removal.
Old Dec 11, 2014 | 01:15 PM
103 sedona orange's Avatar
103 sedona orange
I use HT Silicone sealer & let it kick off before starting bike.
Old Dec 11, 2014 | 01:16 PM
UltraNutZ's Avatar
UltraNutZ
Wasn't talking about Anti Sieze although I don't see where that's not a good idea as long as it's not used as a sealant. I was referring to that gold/orangish sealant crap that Rinehart recommended for a while..
Old Dec 11, 2014 | 01:37 PM
Leftcoaster's Avatar
Leftcoaster
Been using high temp RTV (silicon sealer w/copper) on my mufflers for many years. Never had any issues getting them to come back off. Just spin them on the head pipe and pull back......off they come. Easy-peasy and always a great seal.
As said, anti-seize will dry out from the heat and make the muffs hard to remove. Same goes for axles - use a light lythium grease on your axles and they'll always slide out using only your fingers.
Old Dec 11, 2014 | 01:40 PM
UltraNutZ's Avatar
UltraNutZ
I don't understand the logic behind the anti-seize statements being a bad idea. Do you guys not use the same anti-seize compound on your exhaust port bolts? That area gets hotter than any other part of your engine (except the cylinders themselves) and never a problem with them coming off when needed.
Old Dec 11, 2014 | 05:36 PM
dribble's Avatar
dribble
I use it. It works.
Old Dec 11, 2014 | 09:30 PM
EdandGrace's Avatar
EdandGrace
Great info. Thanks. E series from Fuel Moto to be delivered tomorrow. Might just put a little anti seize on them. Hopefully I'll never have the need or desire to take them off.
Old Dec 11, 2014 | 11:11 PM
RAP's Avatar
RAP
Used Anti-Seize on all my bikes exhaust the last many years. Good stuff, never a problem with it.
