anti seize
Old Dec 10, 2014 | 07:57 PM
EdandGrace's Avatar
EdandGrace
Default anti seize
any reason not to put a bit of anti seize onto the end of mufflers when installing onto head pipes? Easier off when changing? Better seal?
Old Dec 10, 2014 | 07:59 PM
prezflyr's Avatar
prezflyr
I always use anti-seize on exhaust stuff
Old Dec 10, 2014 | 08:14 PM
RollaMo's Avatar
RollaMo
If it is a better seal your after, then they make better products for that.
But the anti seize would make it easier to remove the muffler from the head pipe later on down the road.
I didn't use either when I did mine.
If the pipes are new or used in good condition, you shouldn't have any sealing issues.
Old Dec 10, 2014 | 09:06 PM
dirtdobber's Avatar
dirtdobber
If it is cold it will be harder to remove. The anti seize gets cold it becomes sticky and firm. A fellow brought his rk in for a tire change the had used anti seize on the axle. It was a real pain to get out.
I do not see a problem doing it. Don't over tighten the clamp and you won't have a problem getting them back off. The clamp can make a indent on the header and muffler and make it a real killer to get off.
Old Dec 11, 2014 | 12:39 AM
0ldhippie's Avatar
0ldhippie
I've seen late mufflers slip back, so anti-seize may be a bad idea? I use a little high temp sealer on mine. Never had a problem getting them off?
Old Dec 11, 2014 | 05:47 AM
decencyxdefied's Avatar
decencyxdefied
I use it on mine and it works great
Old Dec 11, 2014 | 05:53 AM
Iceman24's Avatar
Iceman24
"No" on the anti-sieze...use HT silicone (e.g. liquid copper). It's designed for use on this type of application (seals/joints/high-heat/etc.). Created solid seal & allows for easier removal of parts later down the road.
Old Dec 11, 2014 | 05:58 AM
fissco1234's Avatar
fissco1234
I add some penatrating oil, such as "Kroil" to my jar of anti sieze. Keeps it thin and workable at all temps.
Old Dec 11, 2014 | 06:01 AM
Gunnysgt's Avatar
Gunnysgt
2nd on Iceman suggestion. If you feel the need to put somethin in there, that's the stuff to use. Also, make sure you properly torque the muffler clamps, some guys go crazy on tightening them and then make them "out of round" causing leaks.
Old Dec 11, 2014 | 06:14 AM
voodoodrug's Avatar
voodoodrug
I figured id let HD worry about it,so I just used that stuff in a small tube they sell for pipes.
And have avoided taking pipes off by disconnecting shocks instead.
Good idea about warm pipes b4 removing.
I do go crazy with anti seize on other parts that get removed, but I can keep an eye on so I dont lose them like floor board bolts.
