Driving Lights
Old Dec 18, 2014 | 07:14 AM
slburgie's Avatar
slburgie
I put these on my 03 EG which turn amber while signaling- eye catching is what you want.
Old Dec 18, 2014 | 07:58 AM
elPrez's Avatar
elPrez
I've been thinking about these:
https://www.ciriususa.com/
Old Dec 20, 2014 | 08:03 AM
HDJIM1158's Avatar
HDJIM1158
Originally Posted by OldEnuf2NoBtr
Go over to YouTube and type in Cirius Fog Lights. Slickest set-up out there IMO. There was a post about them on here a couple weeks ago.
Do you have to drill holes to mount these lights ???
Ride Safe JIM
Old Dec 20, 2014 | 08:17 AM
HardRider1's Avatar
HardRider1
You want some great engine guard lights these are wonderfully built, provide hi and low output and look decent
http://www.twistedthrottle.com/denal...ith-5-amp-fuse
Old Dec 20, 2014 | 08:21 AM
HDJIM1158's Avatar
HDJIM1158
Ride Safe JIM
Cancel, Found the other posts. I really like these lights but wonder about rust down the road.
JIM
Old Dec 20, 2014 | 08:23 AM
HardRider1's Avatar
HardRider1
These are very cool looking I would guess that you would have to drill into the engine guard to run the wiring, I like these.
Old Dec 20, 2014 | 11:50 AM
bklynbob's Avatar
bklynbob
A lot of good suggestions. I'll add www.rigidindustries.com
Sr-m and Sr-q. They have 4 or 5 beam pattern$$$.
Old Dec 20, 2014 | 07:30 PM
Ragtop's Avatar
Ragtop
They might look decent on a 4 wheeler, or maybe my tractor...
Old Dec 21, 2014 | 10:13 AM
UltraSteveUSAF's Avatar
UltraSteveUSAF
OK so lots of good ideas, I have lowers on my engine guard. So on the RGS I'd like to mount to calipers or fender mount. The lights that mount too the guard from cirius look good if they not only make you visual but give some enhancement to the stock lighting. Anyone running these as driving lights or just so oncoming traffic can see you better?
Old Dec 26, 2014 | 05:29 PM
Oogie Wa Wa's Avatar
Oogie Wa Wa
For the Cirius lights you have to drill two mounting holes on each side and tap with a 4-40 tap, plus a 1/4" hole for the wires to go into the guard, so 3 total each, and it's fairly critical that they are located properly, I'm sure. They said that you would use existing holes in the guard to get the wires out.
I think I'll get the amber ones for my 14 trike, though, should make it look wider from the front. I figure I'll make a drill guide out of some 2x4 stock and a clamp or something to get the alignment right; maybe face then outwards 10 degrees to get a little side visibility, too. Flip the guide over to do the other side.
They do come with instructions on how to seal everything up with silicone caulk or something when you put them on, corrosion shouldn't be a problem.
