Compensator Lifespan
Old Dec 20, 2014 | 06:52 AM
  #61
sporacer's Avatar
sporacer
2010 streetglide with a 120r the SE compensator was wasted at 30000 miles using atf for fluid
2013 cvo roadglide stock 110 the compensator was shot at 2500 miles.
I currently am running the latest updated compensator with a .030 shim to tighten it up and golden spectro 80 wt wet clutch fluid in my 124" monster.
Old Dec 20, 2014 | 08:18 AM
  #62
bigskyroadglide's Avatar
bigskyroadglide
Got 22k on mine 2012 skunk
No issues
18K behind 110. 4k with 120r
Running b&m trick shift atf
Quiet as a mouse
No issues yet
Old Dec 20, 2014 | 08:50 AM
  #63
Dionicio's Avatar
Dionicio
56K on My 08 Ultra. Comp was in excellent condition when checked during stator replacement. Never had any issues with original comp.
Old Dec 20, 2014 | 09:43 AM
  #64
OwnerOfHarriet's Avatar
OwnerOfHarriet
On my 2000 EG, the comp is still stock with 110,000 miles on it -- however with that said, during a hard ride on a very twisty road in 2011 the bolt loosened up. I heard the noise and put another 150 or so miles on it till I got to the dealer -- pulled the cover and found it loose and it had already badly worn the teeth and was going to need a new crank.
Permanent loctited it and torqued it down. That was about 40,000 miles ago -- its still working --I no longer hot foot it.
My 09 CVO Ultra still had the stock comp in it with 21,000 miles when I traded it in -- no problems that I knew of.
Will see how the 14 103 does.
Old Dec 20, 2014 | 01:12 PM
  #65
Larry64's Avatar
Larry64
Originally Posted by Hogpro
I am hearing around February or so. That is right around the corner.
Winter in Michigan, I have time. Mine makes no noise, if feels fine. Just nice to know when it goes I have a reliable option. Fix it once and be done.
TexasMotorcycleRider
2014-2024 Touring Models
Nov 21, 2016 09:02 AM
Ghosttrain1
Sep 30, 2013 08:01 PM
ThePunster
EVO
20
Jul 19, 2012 03:00 PM
MJHJEA
EVO
31
May 17, 2012 09:02 PM
wldbill
Apr 20, 2009 09:04 PM
