Horn Relocation on SG
Old Dec 26, 2014 | 07:35 AM
smithmx47's Avatar
smithmx47
Default Horn Relocation on SG
Hello all, Looking for ideas to relocate the horn, want to clean up that side of the engine. Thinking of putting it inside the fairing. Thoughts , ideas.
Thanks.
Old Dec 26, 2014 | 09:02 AM
barrygreen's Avatar
barrygreen
That's a good idea, possibly find a fork headlight mount like the one below
and modify to mount inside fairing? There is plenty of open space I would think.
http://www.speedmotoco.com/product-p/p833.fu2.htm
Old Dec 26, 2014 | 09:18 AM
Joe12RK's Avatar
Joe12RK
I put a second horn under the left side cover - no reason you can't use that spot for the first one. Just had to break off the two clips that are there.
Old Dec 26, 2014 | 09:23 AM
lhgdale's Avatar
lhgdale
Good idea. Got a pic?
Old Dec 26, 2014 | 09:45 AM
62hdbiker's Avatar
62hdbiker
I put mine in fairing-per instructions for HD cooling fan.
There is a screw hole already there near the right speaker. There is also a horn wire there too. You have to look at wiring diagram to pick correct color
Old Dec 26, 2014 | 11:58 AM
p51bombay's Avatar
p51bombay
wrong thread
Old Dec 26, 2014 | 12:46 PM
Harleyboyddk's Avatar
Harleyboyddk
Ditto on the HD cooling fan install directions for mounting inside fairing. Cut the horn mount off the engine mounting bracket and you're good to go. You won't be reusing the mount, just cleaning up the area between the cylinders once horn is removed.
Old Dec 27, 2014 | 08:04 AM
Joe12RK's Avatar
Joe12RK
Here's the horn under the side cover:
Old Dec 27, 2014 | 08:14 AM
smithmx47's Avatar
smithmx47
Thanks guys . Put it in the fairing. Used up both side cover spaces with air ride remote and compressor.
Old Dec 27, 2014 | 01:53 PM
crimson13's Avatar
crimson13
I did this also works good.
