Tour Pak Modification Question
Old Jan 7, 2015 | 01:39 PM
9Rockr's Avatar
9Rockr
2nd Gear
Question Tour Pak Modification Question
I am looking to go with a hidden antennae for my Electra Glide and want to get rid of the antennae mounts that are on the rear "light" bar on the tour pak. Is there a company that makes one without the antennae mounts or do I need to do some sort of custom job? I was looking at the HD LED setup for the tour pak but even that has the antennae mounts.
Old Jan 7, 2015 | 02:02 PM
mkguitar's Avatar
mkguitar
Welcome to the Forums.
I know this question has come up before, you may get a quicker response by searching for old posts.
the search function on these forums are great.
Mike
Old Jan 7, 2015 | 02:54 PM
user 8373900's Avatar
user 8373900
I think some of those plastic plugs with the bar and shield that are used for the rear fender seat bolt hole on the softails siliconed in there would be nearly unnoticeable? And only a few bucks.
Mark
Old Jan 7, 2015 | 07:02 PM
Stang951's Avatar
Stang951
I got some short antennas (like 3") and installed those. Most people think that they are functional even though they arent. You could use some type of plugs if you removed the antenna posts from the assembly also.
Old Jan 7, 2015 | 07:38 PM
Uncle Larry's Avatar
Uncle Larry
Mark
Yep ... I've put "vacuum plugs" on the studs and they look like they came from the factory ... very inconspicuous and understated ...
Old Jan 7, 2015 | 09:40 PM
TSheff's Avatar
TSheff
Exactly what I did. In fairing antennas & vacuum plugs. They will split after 2-3 years so be prepared to budget for another $.99...
Old Jan 7, 2015 | 11:20 PM
9Rockr's Avatar
9Rockr
2nd Gear
Mike
Did that before I put the post up, didn't find an answer. Thanks for the help.
Old Jan 7, 2015 | 11:22 PM
9Rockr's Avatar
9Rockr
2nd Gear
Mark
That is a good idea, think I might go that route.
Old Jan 7, 2015 | 11:57 PM
p51bombay's Avatar
p51bombay
On mine I removed the studs and silicone'd in some hole plugs - almost disappears.
OldTimer
Apr 7, 2010 07:34 AM
Badbagger
Mar 24, 2009 09:57 PM
BillyG0856
Apr 3, 2008 05:22 AM
BB06FLHX
Jul 3, 2007 12:18 PM
Neil
Jan 11, 2007 07:51 PM
