High Pitched Chatter
Old Apr 16, 2007 | 11:09 PM
Corndog's Avatar
Corndog
Default High Pitched Chatter
After the dealer installed Rinehart True Duals on my '07RKC, I've noticed a high pitched chatter coming from the rear of the bike. At first I thought it might just be the 6th gear whine, but it does it in 4th gear too. It is very apparent when driving through a bridge.I tightened the end caps and the support brackets...no help. Any ideas? Maybe the heat shields rubbing somewhere?
Old Apr 16, 2007 | 11:12 PM
UltraKla$$ic's Avatar
UltraKla$$ic
Default RE: High Pitched Chatter
Sounds like something is loose and/or rubbing. Go over all fittings with a wrench. Also make sure that the rubber grommets under your saddlebags are still there since they probably removed the bags. There should be 2 grommets for each side in the channel under the saddlebag that ride on the saddlebag support bar.
Old Apr 16, 2007 | 11:16 PM
dougbk's Avatar
dougbk
check to make sure your exaust pipes aren't touching anything they shouldn't such as floor board mounts.
Old Apr 16, 2007 | 11:17 PM
Corndog's Avatar
Corndog
Whoops....I meant the 5th gear whine....
cajun1957a
Apr 15, 2020 11:41 AM
All Aces
Sep 1, 2010 10:34 PM
Clint55
Mar 4, 2010 07:06 AM
Olyone
31
Aug 31, 2009 09:33 PM
dog155
Jan 15, 2007 11:43 AM
