Finally did it
Old Jan 22, 2015 | 08:32 AM
prezflyr's Avatar
prezflyr
Default Finally did it
I finally changed out my Hogtunes front fairing speakers in my 2009 Ultra. I had removed my stock front speakers a few years ago and went with Hogtunes. I was happy with them over stock but wanted a little more. I went with the 7 1/4" J&L's with no amp. I think the Hogtunes were better sounding and had more bass and clear sound. My question is, do I need an amp? The other question is, the J&L speakers sounds weak with the radio but sound 100% better when playing music from my I Phone. Why is that and should I just not listen to the radio and use my I Phone for music.
Old Jan 22, 2015 | 08:36 AM
EasternSP's Avatar
EasternSP
I went with the HogTunes back in 2010. I added an amplifier too. I don't see much difference between with and without the amp, especially while running over 65 or so. At lower speeds, the difference in the volume you can make up with just increasing the volume level. Unless you're playing music for the parking lot around you, an amplifier isn't really all that much more in volume.
Old Jan 22, 2015 | 08:44 AM
speednut's Avatar
speednut
Until someone who knows more chimes in. Some radios have more power than others and some speakers work better with more power than others. Seems from what I read in your post this may be the case check the box on your new speakers to see at what range they are rated for and see how much your radio puts out.
Old Jan 22, 2015 | 09:02 AM
hdbob2006's Avatar
hdbob2006
Check the ohms rating too. I believe your stock ones and the hogtunes will be 2 ohm,if you put 4 ohm speakers in it,you"ll lose a lot of sound.[with or without an amp]
Old Jan 22, 2015 | 09:46 AM
SilverEagle50's Avatar
SilverEagle50
Guys, you have one of the best sights for audio right here on this sight. go to the tech forum and choose the audio section. There are others on there too, but UltraNutZ is "THE" man for all audio. There is plenty on that forum to answer any and all of your questions.
And YES, an amp makes all the difference in the world. Better sound, fuller sound, and obviously more sound. People ask me all the time if I can hear my music at speed. If I want, I will only hear music. It will drown out the bike and the wind. (not that I play it that loud though)
the best setup for your buck is the fosgate amp and Polk MM651 speakers.
Old Jan 22, 2015 | 10:05 AM
billbuzz's Avatar
billbuzz
My riding buddy put the hogtunes speakers on his 2012 road glide with no amp. It is a slight upgrade but when he heard my new biketronics 2180 amp with the 7.1 speakers he ordered the same combo for his bike. Sounds awesome.
Old Jan 22, 2015 | 11:01 AM
SBates08's Avatar
SBates08
All I can say is you installed the wrong amp. The right amp for your setup will make a HUGE difference.
2010 Limited with some stuff!!
Old Jan 22, 2015 | 11:31 AM
campos's Avatar
campos
you definitely need an amp!
Old Jan 22, 2015 | 01:03 PM
Big Money's Avatar
Big Money
Ditch the factory head unit, Biketronics 4180 amp, 7.1's, Biketronics 6x9's in saddlebag lids and it will play as loud and clear as you want. Stock head unit really holds back any system.
Old Jan 22, 2015 | 01:45 PM
prezflyr's Avatar
prezflyr
Thanks, I also seems that there is little sound difference from 1/2 volume to full volume. Maybe my radio is dying. Which amp should I get with the 7 1/4" J&L speakers?
