Minimum/maximum baffel size
Old Jan 28, 2015 | 10:09 AM
Babyboy's Avatar
Babyboy
Default Minimum/maximum baffel size
I have searched high and low and was wondering is there a minimum or maximum baffle size recommended for a 2014 flhtk Running a stock tune? I am looking at changing out just the mufflers for now until the wallet gets a little fatter and get a tuner.
Old Jan 28, 2015 | 10:18 AM
DHubbs's Avatar
DHubbs
Most dyno tuners will tell you to not go over 2.25". At 2.5 you start losing bottom end torque. Steve @ Fullsac performance recommends 2" for the best tune. I have his 2.25" power cores in stock CVO cans. They reacted very well with a TTS tune on the dyno. Sounds great too IMO. http://fullsac.com/product/2006-2015-cvo-power-core/
Old Jan 28, 2015 | 10:26 AM
mkguitar's Avatar
mkguitar
the reason(s) being that a narrower core has more velocity for the exhaust gasses.
and wider may have less velocity, less restriction
exhaust systems are a compromise and the work best with the characteristics of the motor "about" 2" is better for most motors, most conditions.
if you choose wisely, you can start with mufflers which will still work if you change headers, intake, cams, displacement, headwork etc.
a poor choice gets you chrome piling up in the garden shed.
so before you start spending, figure out a system approach and add part incrementally as finds allow.
determine your desired result- for some riders it is power, for others sound.
some of the Guys here have spent thousands on 2 or 3 or even 4 sets of exhaust for their rides
mike
Old Jan 28, 2015 | 01:55 PM
Rush Racing Products's Avatar
With stock head pipes the cat provides a lot of back pressure.
We recommend the 3.00" or 2.50" baffles.
If you had an 09 with stock headers and no cat we'd recommend the 2.00" or 2.25" baffles.
jon1120
Feb 20, 2017 11:15 AM
jlasoftail
Aug 19, 2016 06:54 AM
slowrollin
Exhaust System Topics
Dec 31, 2015 10:13 AM
junglejoe
2014-2024 Touring Models
Oct 17, 2015 08:57 AM
B00001
Aug 26, 2013 11:59 AM
